Questions re: your cause.
O.K., I have it set up correctly now on both PC's, with client setup behind firewall, socks5, host name: Midpoint. Works! Using tacube.teamanandtech.com.
Also have email ID setup as: rc5@tacube.com
I take this to mean everyone that sets it up with rc5@tacube.com gets combined as the team.
But, how do individule stats get updated correctly, especially if your login IP changes everytime you connect? How do stats work with mulitple PC's sending data, (like the 2 I have)?
ThimOthy : Sneaky always makes a backup on your disk. The file containing your packets is buff-in.snk. Just take another safe floppy, put buff-in.snk on it and rename it buff-in.rc5.
NOTHING is lost until you fetch again with sneaky.
BTW : What version of Sneaky are you using ? The new 2.30 version don't fetch packets anymore but WUs instead. The new maximum is 99,999 Wus. I could increase this max if there is a demand for.
that's the thing... i took that snk file and renamed and then moved it, so yes, it's gone... :-( i get about 70k WUs from 99999 * 2^33 setting.
