For highest overclock buy yourself a tuniq tower 120 or 120 extreme, 10 to 15c better temps than a Hyper 212/412 and its only $20 dollars more. Just make sure you buy standard height ram not the ones with big heatsinks or it won't fit.
Yeah I don't think could find those models around here..
The better stuff I found was this a Corsair H80 wont buy those until 3 months or more.
So finally after thinking like a complete night, I got this;
SB Pros:
* It is Good for Overclocking, (good temperatures)
* Not bad compared to IB
* People have more experience with it (which they can help you overclock its faster and easily).
SB Cons:
* More consumption compared to IB
* Old technology compared to IB
* Worst IGP if you want to use it, or use in Virtu MVP (not sure about this yet), compared to IB
* There is no PCI 3.0 (useful for New high end Video Cards and Oced ones).
* No native support for Memory 1600 mhz Ram (yea it doesn't matter that much, but still)
IB Pros:
* Less consumption.
* PCI 3.0 support
* Better IGP, may increase a little performances for games (not sure about this yet)
* Native support for 1600 Mhz ram
IB Cons:
* Bad for overclock produces more heat (unless you change the thermal paste inside the "cake", so It can transfer more heat to dissipation)
* Difficult overclocking, not mature enough yet
Hope all of this is correct, and so I have to decide stick with the Ivy Bridge, sadly Intel make a bad move doing that with the thermal paste, but still if you are on a budget like me it is going to be hard decide for one or the other, and because I'm only thinking overclocking it to 4.2, don't think I could risk more or over-voltage it, My plans are to try to overclock it with default voltage.
Appreciate all the answers, you guys make me search for info as hell with answers I didn't understand, so I learned a little more of all this stuff.
Ill be around when I got that CPU searching for Info to overclock it with default volt, I hope my 412 is enough for this task. Please let me know if I should know something related to this topic.
So thank you again guys and moderator can close this, or I don't know how it will work, I come from forums where if you find your answer it must be closed.
Cheers.:thumbsup:
http://www.computo.com.pe/productos...-lquido-corsair-h80-material-cobrealuminio-di
