hardcore_gamer29
Rubber pads very small square shape not thetmal pads . Manual says if nvme ssd is double sided dont use and if single sided use it. I am confused i have samsung 980 1tb 2280 mWhat rubber pads? Do you mean the thermal pads on the heatsink of the motherboard? If so, yes use them, do not remove them. You do need to remove any plastic film that may be on them.
argb, the 5V one. Again, from the manual.
Leave? It says if single sided we need to install .Gotcha. Some NVME drives have chips on both sides. It looks like yours does not, so leave the rubber pad.
