Info PrimeGrid Challenges 2025
Separate clients also help with different amount of Queues. Plus WUProp counts 8 CPUs and a 1 GPU as 9 so each hour a task would only get 8/9ths of an hour towards WUProp. Even Radioactive counted as overloading more tasks than threads.
I have Process Lasso on Windows but I mainly use it to give any GPU exe it's own thread.
Can you explain that more? Because that doesn't seem like that's how wuprop records duration of running tasks.
Say you use ncpus in cc_config to run 10 CPU tasks at once on 8 threaded system. For each task you'll get 8/10ths of an hour per task to still get 8 app hours per hour. A GPU task counts as another running task on top of the CPUs. Radioactive was either inhibiting a CPU task running or counting as other CPU task so I moved it to my GPU client awhile back.
I was pretty sure it had factor in the task info but forgot its all in French so it was facteur.
Maybe it no longer does that as I don't see that message in other users tasks.
Day 1 stats:
Rank___Credits____Username
1______18668606___Icecold
5______11205600___[TA]Skillz
6______10997064___crashtech
10_____6878355____markfw
19_____2237601____mmonnin
21_____2162068____cellarnoise2
62_____858878_____biodoc
98_____476477_____Ken_g6
104____437261_____IEC
122____371647_____waffleironhead
125____352807_____johnnevermind
130____315494_____w a h
207____127098___10esseeTony
439____1884_______zzuupp
442____1883_______geecee
Rank__Credits____Team
1_____55092732___TeAm AnandTech
2_____24454467___SETI.Germany
3_____21277014___Antarctic Crunchers
4_____18364434___BOINC.Italy
Reportedly three or four primes have been found in this challenge already! Maybe by some of you?
In preparation of the heat, (its already 61f outside and hotter the upcoming week) I have every window and door open.
I didn't want to, but have windows open since last night too. Regarding heat at home, it's bad that GFN-18 works well on CPUs *and* GPUs, and it's also bad that I am guest-computing for a team which unlike TAAT is surrounded by competing teams, so I couldn't help but switch on more than I originally intended.
Also, I still neglected to put mosquito screens together. Of course there aren't any mosquitos active at this time of year in Germany, but it's the time of year at which bumblebees are looking for new homes. I hope they all find their way out of my apartment like they do find their way in now.
I had to close the house up. Its already 80F outside and thats what the AC is set to. I can't cool outside.
Day 2 (late) stats:
1______43544141___Icecold
5______25328225___[TA]Skillz
6______23262346___crashtech
10_____13190730___markfw
11_____10007383___cellarnoise2
19_____5110952____mmonnin
101____1109382____w a h
113____942404_____Ken_g6
120____890238_____IEC
125____858878_____biodoc
129____828129_____johnnevermind
140____722703_____waffleironhead
287____127098___10esseeTony
456____9418_______geecee
471____7542_______zzuupp
1_____125939577___TeAm AnandTech
2_____53884827___SETI.Germany
3_____43869633___Antarctic Crunchers
4_____41126164___BOINC.Italy
Congrats to @emoga on passing me. 😉
Day 3 stats:
1______65184437___Icecold
5______37394506___[TA]Skillz
6______33489936___crashtech
10_____18627833___markfw
12_____14568288___cellarnoise2
19_____7585953____mmonnin
108____1594844____w a h
122____1334393____Ken_g6
131____1193418____IEC
134____1184496____johnnevermind
141____1099018____waffleironhead
165____858878_____biodoc
270____265363___10esseeTony
463____15082______geecee
482____11313______zzuupp
1_____184403930___TeAm AnandTech
2_____79930743___SETI.Germany
3_____64350782___Antarctic Crunchers
4_____61131506___AMD Users
Got a respite with some cool rainy weather so now all the GPUs are pointed at PG for the duration of the race.
Well, except for the 9070XT which doesn't want to run on PG.
Day 4 stats:
1______86943596___Icecold
5______50691322___[TA]Skillz
6______43853780___crashtech
10_____24598078___markfw
14_____19692051___cellarnoise2
21_____10312223___mmonnin
104____2225801____IEC
109____2115487____w a h
130____1722329____Ken_g6
132____1650226____johnnevermind
143____1499385____waffleironhead
194____858878_____biodoc
207____746150___10esseeTony
458____24533______geecee
507____13205______zzuupp
1_____246945135___TeAm AnandTech
2_____108624970___SETI.Germany
3_____92641989___AMD Users
4_____92060518___Czech National Team
At the current rate, AMD Users and Czech National Team are going to end up very close to SETI.Germany. The battle for 3rd place could escalate to a battle for 2nd...
Even though I have had a pretty secure 10th place for days, MIHost passed me last night. I am now 11th.
Looks like I'm gonna finish 5th. Can't believe I am that high in the ranks with what I have.
after a couple of days, I stuck with just the 4090s and 4080s video cards. 9 cards got me to 11th. The 64 core CPUs, even with lasso correctly configured did not seem to make much difference, and the heat was more than I could deal with. I have had the AC on, set to 78-80 degrees for days now. and thats with just 9 cards running.
That's because you didn't have your CPUs set up correctly. My dual genoa was doing over 2.5M PPD. Roughly 1/3 of your total output. The inside temperature of my apartment right now is 88F. It's hot.
edit
Even my Rome 64c CPUs were doing over 550k PPD. Pretty sure that's about as much as a 4080 or 4090.
edit
The majority of my points (maybe something like 75%) were from CPU's. A properly configured 64 core Genoa should do over 500 tasks per day (nearly a million points). A 4090 running at full power not power limited in comparison does around 350 tasks per day.
More-or-less final stats:
1______106228164___Icecold
5______60655513___[TA]Skillz
6______52792766___crashtech
12_____29008940___markfw
15_____23992716___cellarnoise2
21_____12526755___mmonnin
95_____3159303____IEC
112____2560543___10esseeTony
116____2486100____w a h
131____2112259____Ken_g6
134____2026099____johnnevermind
152____1769106____waffleironhead
209____858878_____biodoc
477____24533______geecee
503____18883______zzuupp
1_____300220565___TeAm AnandTech
2_____131706484___SETI.Germany
3_____127158475___AMD Users
4_____124053060___Czech National Team
I picked up the pace a little after @TennesseeTony passed me (and @emoga and several others) and johnnevermind threatened to.
Whaaat? Did I do that? I was merely collecting data to see how the new to me mobile 7950X (almost equivalent) systems compared at different power levels. All those 4090's and other systems running GFN18 the last 17 hours must have been a mistake in my preferences...cough cough. 😀
In all honesty though, I have met all my PG goals for now, and plan to participate as little as possible this year. I want to get back to medical projects. And I want to run 24/7 year round. And I have a budget of $100 month for energy.
This leaves me with 6 of the minisforums, running 83watts CPU, 120w at the wall, a soon to be upgraded to 64 core Epyc Rome (equivalent to 2 desktop 7950X), and a 7950X desktop. GPU use will be seldom.
And Ken, I don't think we thank you enough, for the work you do for the TeAm, and for the BOINC community at large. THANK YOU.
And @Kiska , the same goes to you! THANK YOU.
How is ~8 hours for the type units in the upcoming contest ?
PrimeGrid 9.51 Generalized Cullen/Woodall (LLR) (mt) llrGCW_662112230_0 02:03:44 (15:55:12) 96.49 25.935 05:52:17 09d,21:56:08 8C Running Turin
Closer to 8.6 hours average, that is with lasso in 8 x 8 config.
That seems about right based on what I'm seeing on my machines. 8x8 is the correct config. GCW is a difficult project to run, especially on cloud or older machines, so you should do well depending how many of your machines you put on it. The last time there was a GCW challenge you came in first place - https://www.primegrid.com/challenge/2024_6/top_users.html
A little less than 6 hours to go. I have the fleet powered up, ready to configure and run. (lasso after I let loose the BOINC tasks.) 624 cores without SMT.
One of these is a 9950x and one is a Turin, so a splattering of Zen 5. The fan pictured below keeps the VRM on the Turin below 100c (its at 70c now)
