Post your Fritz Chess Benchmark Results
heyheybooboo
6,278
I'm not so sure Phritz is very Fenom Phriendly --- I'm bouncing all over the place. Maybe I shouldn't have run it off a thumb drive :p
Phenom 940BE
3.2GHz / 2200MHz NB
15.13 sec
7,262 kn/sec
3.4GHz / 1600MHz NB
16.02 sec
7,689 kn/sec
3.4GHz / 2200MHz NB
17.05 sec
8,192 kn/sec
3.4GHz / 2400MHz NB
16.12 sec
7,738 kn/sec
I up the cpu and drop the IMC/NB and get a nice bump.
Keep the cpu the same, up the IMC/NB and get a nice bump.
Keep the cpu the same, up the IMC/NB and fall way back.
Best Score:
3.6GHz / 2400MHz NB
17.42 sec
8,361 kn/sec
(Too lazy to run 2200MHz NB - would have had to reset CMOS)
At this speed my times varied by as much as .5/sec (down-LOL) and 500 kn/sec (ditto) over 4 runs.
DDR2 800 5-5-5-18 (I think) - 2T
MSI 790FX - sb600 - 80Gb IDE (Yippee!)
Idontcare
21,110
64
Are you crossing some funky clock-domain threshold deal like folks do with the NB Strap on LGA775 platforms in which the latency for the L3$ and/or dram takes a step back despite the bandwidth continuing to increase?
Idontcare
21,110
64
Originally posted by: ImDonly1
My scores
Q6600 at 2.4 Ghz - 2x2GB DDR800 I think the timings are 5-4-4-15-2T
Win 7 x64
Relative speed - 13.55
Kilo nodes per second 6506
That's much closer to my score in my post above, my memory timings are 4x2GB @DDR2-800 and 5-5-5-18-2T. Everything is set to stock, FSB is 267, etc. Mobo is an Asus P5E-WS Pro.
Makes me even more curious what the special sauce is in oogabooga's rig, 5% more performance at same CPU clockspeed is something I don't want to be leaving on the table.
heyheybooboo
6,278
Some funky mojo it certainly be - LOL
I'm not really into the 'benchie' thing - I've never seen folks complaining about backing up in this fashion but you have a great point.
I ran 3.4GHz 2400MHz NB again and got 15.74/sec --- 7,554 kn/sec
One thing I did check this time:
Mem Usage: 265,860 K
VM Size: 263,768 K
Page Faults: 66,478
So I'd say I'm working almost entirely off my page file on that 80Gb IDE hard drive :D
edit: Okay ....
I mucked around with my memory mapping and went 16.73/sec --- 8,030 kn/sec at 3.4GHz 2400MHz NB again (with 75 fewer page faults than above).
I quit.
(mmmm .... but I wonder what my page file would do on an SSD drive? - and how much I'm really hitting it? )
Idontcare
21,110
64
Originally posted by: oogabooga
Q660 @ 2.40GHZ
4.00GB DDR2
Logical Processors found :4, used :4
Relative Speed : 14.53
Kil Nodes per second : 6974
oogabooga what are your dram timings and OS?
I have same, Q6600 @2.4GHz with 8GB DDR2 on WinXP Pro and my results are quite a bit lower (5%) than yours:
Relative Speed : 13.83
Kil Nodes per second : 6636
I'm curious what is different about our rigs as to make a 5% performance impact in this bench.
Never mind, you must be using DDR2-1066.
This Fritz program really depends on the ram bandwidth I see.
At DDR2-533 I get 13.1 and 6288
At DDR2-667 I get 13.48 and 6468
At DDR2-800 I get 13.83 and 6636
That's graphs out to a linear line with R^2=0.9997.
This projects to around 6984 at DDR2-1066 (can't test with my ram, but it's right at what oogabooga is reporting.
dguy6789
8,558
snip
Are you guys running the same motherboard? Back in the Pentium 4 and Athlon XP days, motherboard and chipset reviews seemed more common and indepth. I recall that the difference in synthetic benchmark performance can be several % between different motherboards on otherwise identical systems. These days I almost never encounter articles that try to figure out which is the fastest motherboard.
GLeeM
7,199
128
Originally posted by: GLeeM
DDR3 6 GB CPU-Z shows timings are 9-9-9-24-1T (how do I find speed?)
On the memory tab in cpu-z, in the Timings section, the first row is DRAM Frequency.
Multiply this number by 4 for DDR3, by 2 for DDR2.
DRAM Frequency was like 720 and I have DDR3 so I think it is multiply by 2. I checked in the BIOS and two times is what it showed.
Otherwise it would be 2880 and this ram is rated 1600!
Once I was in the BIOS I tried some higher runs:
i7 920 @ 4.0 (200x20)
DDR3 1600 9-9-9-24-1T
rel speed - 30.39
knodes/s - 14,588
and:
i7 920 @ 4.2 (210x20)
DDR3 1678 9-9-9-24-1T
rel speed - 31.95
knodes/s - 15,336
I tried at 4.4 and 4.3 but it wouldn't enter Win7. This was the first time I had it over 4.0.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Your 30.87 and 14,816 seem to indicate that you lost your Turbo boost during the bench run. It would have been 4.0 Ghz (200x20)
Yes that's the familiar turbo throttling!
Mr Fox
876
Originally posted by: Mr Fox
http://img191.imageshack.us/img191/3915/fritzchess.jpg
CI7 920 D0 @ 4.2 Ghz (200x21) DDR3 1234 Mhz x 6GB.
No my memory is dialed back... the CPU is brand new...so i'm being gentle
I was able to hit 3.6 GHZ Undervolting @ 1.17VCore
I'm also running the ROG BIOS...and Turbo is disabled...
GLeeM
7,199
128
He's right! It does make a big difference :shocked:
I really don't know what I am doing, but someone ;) here says we should be able to do 4.0 Ghz at (I think it was) 1.1VCore. So after benching I went to 3.7 @ 1.16 (from 3.6 @ 1.20)
Rhoxed
1,051
Phenom 2 x3 720BE @ x4 3.825Ghz 2.815Ghz NB
4GB DDR2-1080 5-5-5-20
Relative Speed: 18.94
Kilo nodes per second: 9109
will run it on the 940BE and at higher clocks soon
EDIT: seems like this bench doesn't like AMD much
Idontcare
21,110
64
I finally got around to uploading the graph showing the correlation.
Fritz Chess Memory Bandwidth Scaling
The green points are experimental data, the red is what the linear fit extrapolates to for a DDR2-1066 value. I can't take my memory there to test it, crappy ADATA stuff that I'm just happy will run at stock.
2March
135
i7 3.8 GHz (180 x 21)
P6T-DL
2 x 2GB 1066 MHz 6-7-7-20-1T
relative speed: 28.39
kilo nodes/sec: 13628
Triplehammer
12
e6600 OC @ 3.0Ghz, 2 x 1GB DDR2 1000 5-5-5-15
Relative speed: 9.00
Kilo Nodes/sec: 4320
Gee, I guess more cores trumps everything on this test.
A bit more explanation on the RAM speed: I bought DDR2 1000 RAM, but the BIOS says it runs at 800, because I set it the way I have due to this advice: "If you only want to push your e6600 to 3ghz, you wont be able to overclock your ram. The reason is that 3000mhz = 333mhz (fsb) x 9 (default multi). The highest divider available would be 266mhz ref frequency - 800mhz mem frequency = 2:3 divider = 333fsb/500mhz ram --> DDR2 ---> 1000mhz ram wich is the default timing for your ram." The motherboard is an Intel D975XBX2 (aka Intel Bad Axe 2).
Wuzup101
2,334
37
Relative speed: 7.78
Kilo nodes / sec: 3733
Mobile C2D P9600 (2.66ghz / 9x266mhz / 6mb L2)
4GB DDR2 800
Laptop is a dell e6400 (latitude)
Far too lazy to turn the desktop on...
