We have a winnar!Originally posted by: Topweasel
Terminators, He is using SCSI (this a guess good guess but a guess).
Originally posted by: anarchyreigns
Mine: http://pg.photos.yahoo.com/ph/mpcurl98/album?.dir=/a87b
Originally posted by: ReMeDy{WcS}
Originally posted by: Jeff7181
My mess
That's a mess. But, it's a mess of share lazyness. You can easily formulate management out of what you have there.
1) Route the Power supply 20/24 pin cable under the motherboard to come under the Power socket. There is alot of slack, and that can be hidden under the PCB itslef.
2.) Your SATA cables can also be routed on the under edge of the motherboard to meet the SATA header.
3.) Your USB/PCI header can be routed in parellel with the PCI slots to meet the header. Or, it can be routed right under the Audigy card and hooked back using an adhesive and zip ties to the PCI slot itself to secure it to meet the header.
4.) If those beige cables in the front of the chassis by the 80mm fans are Frontal USB/Firewire/Audio cables, that you're not going to use. Then zip tie them to the HDD cage up above threading the zip tie to the holes in the cage. As a harness.
*shakes head*
JMO....
Originally posted by: tasburrfoot78362
You have to get pin extractors to remove the ends, then you sleeve the cables, and then you put the ends back on.
Tas.
Holy crap that makes me nervous just looking at it on the ledge like that...TAKE IT DOWN HURRAY BEFORE IT FALLS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Originally posted by: YOyoYOhowsDAjello
With HT wiring like this right next to my computer, I've given up on keeping things neat
Let me see if I can find a picture of my old attempt before I gave up...
EDIT: I gave up looking for the picture too![]()
Once you get it, could you give a little review of it here? It looks rather nifty.Originally posted by: djnsmith7
Tas.
That's not entirely true. Thanks to the information in this thread, I came across the product listed below which I'm going to purchase & use to rearrange my cabling this weekend. This stuff looks really cool.
http://www.svc.com/sleeving-flexo-wrap-pet-sleeving.html
