silverpig
- Jul 29, 2001
- 27,703
- 12
- 81
Originally posted by: adlep
Europa...Buts thats a moon...
It has plenty of water though....
Jupiter. We got Europa for water + solar system's largest hockey rink, Io, Ganymede...
I also think that given time Venus could be habitable. The general makeup of Venus is remarkably similar to that of Earth. Most of the heat on that planet is trapped due to the atmosphere in a process similar to global warming. If venus had an atmosphere similar to earth it would be quite habitable, though admittedly a little hotter.Originally posted by: zayenedyour sickOriginally posted by: LordMagnusKain
i think that Venus isn't as un-inhabitable as some make it out to be.
on earth at the equator it gets to be 110 sometimes and thats unbearable
how hot you think Venus gets???
Earth has an equal amount of carbon dioxide as Venus. The difference is that most of the CO2 here on Earth has been locked up in rock formations under the sea. If all of that CO2 was released here, our planet would be exactly the same: a blazing oven. If we had a way to trap the CO2 content on Venus it could be habitable.
I'm thinking sulfur accepting plants, our subs can withstand those atms.
but mars does look more terraformable
Originally posted by: Spoooon
Venus probe info.
Mars is by far the easiest solution to colonize/terraform, I'm just trying to say that it isn't impossible for us to eventually live on Venus. One of the biggest sticking points is how long the days are on Venus, 240 days or something like that. I don't think earth plants would handle that very well even if we could get the temp low enough. If we could find a way to harness the heat energy in the atmoshpere to speed up the rotation of the planet then.....Originally posted by: LordMagnusKain
Comparison to Earth:
Venus and Earth have roughly the same size and mass. At its equator Venus is 12,104 kilometers in diameter (or 0.95 times that of the Earth), and its mass is 0.81 times that of the Earth. Both planets also have few craters, indicating relatively young surfaces. The planets also have similar density and composition as well.
Comparisons of the two planets' rotations, however, illustrate a key difference. Venus rotates on its axis in a direction opposite that of the Earth and the other planets of our solar system and takes 243 Earth-days for a complete rotation. One revolution around the Sun for Venus takes 225 Earth days. Because Venus takes longer to rotate on its own axis than to complete a journey around the Sun, one day on Venus is slightly longer than one year there!
Venus probe info.
Thanks for the link!
"The hardy spacecraft had delivered the first measurements conducted directly on the surface of another planet. The data confirmed what has already been speculated about the "weather" on Venus -- the surface temperature was 460 to 475 degrees Fahrenheit (237 to 246 degrees Celsius) -- enough to melt such metals as lead or zinc. The atmospheric pressure at the surface turned out to be around 93 atmospheres, comparable to an ocean depth on Earth of around 2,625 feet (800 meters)."
Venus probe info.
temp and pressure all within do-able limits for application specific bio-spheres.
Venus probe info.
but mars is sooooo much easier, venus is do-able when 100 years off? We could colonize mars now.
Venus probe info.
well, our life time for tera-forming... we'd have it going well now if they'd implemented Carol Sagan's suggestions back in the 70s.
Originally posted by: AnitaPeterson
also, a revival of the Orion projest will be needed for any serious undertaking in any direction, unless someone finds cheap and reliable fusion....
a couple of observations... Mercury has one side facing the Sun, perpetually... that reduces the available surface...
Funny how Soviets/Russians were more "into" Venus, and the U.S. more "into" Mars....... The asteroid belt will be a hot spot for the industry, since so many elements are available there. So it's logical to assume the connection with Earth will be through either a large Jovian satellite or Mars. In any case, Mars is the most feasible overall, and it has the psychological advantage of having been known by everyone.
Originally posted by: rh71
What is this asteroid belt you speak of ?
It seems from here, Mercury isn't tidal locked with one face always towards the sun.
