Originally posted by: Nek802
is there a guide explaining and comparing all these different types of music files from LAME, EAC, FLAC and all the other stuff?
cause all I know is MP3 and wma files...
/q]
Same and I know ogg also.
Its rather confusing to me as things stand.
Originally posted by: 0roo0roo
Originally posted by: EglsFly
Well, I had been using 128K CBR for a compromise between quality and space. I had chosen this because I use MP3 for my car audio player (Alpine CDA-9847) with 700MB CDR discs, and my portable MP3 Player (512MB Creative MuVo N200).
After reading everbody's responses, I am thinking perhaps I should rip to VBR instead?
Although I am not sure if the MuVo supports it?
I use EAC with LAME, I noticed that EAC has different options for VBR.
Such as VBR 128K, VBR 160K, etc...
How do these differ if its variable anyways?
muvo supports vbr. any player worth buying supports vbr and higher bitrates. as for how they differ, the stated bitrate is the average it tries to achieve. thats how it differs. here are the presets http://www.hydrogenaudio.org/forums/index.php?showtopic=28124
http://forums.afterdawn.com/thread_view.cfm/1912fine tuned settings that simplify choices. i waver between extreme and insane..depending whether the music deserves the space.
Thanks for the links.
Will have to try a test of VBR 192K and CBR 192K.
Also, I have Nero6 Ultra Edition. It includes software to rip to mp3. For the encoders, it includes "PowerPak LAME mp3 encoder" along with mp3Pro. Anybody tried the Nero tool or should I just stick with the EAC/Lame combo?
Is there a way to rip mp3's at the same volume level with either of these (EAC or Nero) or do I need to try that MP3Gain software?
Thanks.
What level of mp3 compression would give you near CD quality?
-extreme lets LAME decide which tracks and parts of the music need a higher bitrate.Originally posted by: EglsFly
I am getting ready to re-rip all of my CD's so I want to make sure I got EAC/LAME setup decent.
If I use:
--alt-preset cbr 192
would that be good?
