Poll: MP3 Compression Bit Rate?
Originally posted by: Bona Fide
I use 320kbps for all mp3's I get from online or wherever, but I've started to use Apple's Lossless Format for CD's. It sounds so crisp and it's as close to real as you can get. I'm thinking of converting my mp3's to AAF but idk if it'll work.
Wrong in so many ways I don't even know where to start...
Originally posted by: FeuerFrei
I go for maximum bit rate. Quality is most important. I'm in no danger of filling my 20 gig mp3 player, so file size be damned!!
Agreed.
I always choose the highest quality I can get.
Variable, it seems to average about 175 to 200 kbps, although if I were to pick a constant rate I would use 160 or 192 for most applications.
I would also like to make the switch to Ogg, but I want it to become more widely accepted first...whatever happened to it replacing MP3, and did ogg format video ever come out?
Hey How does MPC (Musepack audio) and WMA compare?
Both lossy compression
Microsoft originally claims wma offer twice the quality over the mp3 of same bitrate
I've got a few mpc files. They are about the same size as 320kpbs mp3
I've yet to have really look into the quality.
Well on their website with test evidence they claim it's the suprerior lossy compression
Musepack is an audio compression format with a strong emphasis on high quality. It's not lossless, but it is designed for transparency, so that you won't be able to hear differences between the original wave file and the much smaller MPC file.
FLAC and Monkey Audio loseless compression scheme are simply too big for my liking
I haven't got any audiophile equpiment anyway to spot the difference
I've got a few hundred CD's I should probably redo in FLAC when I get the chance, then archive them to two sets of DVD's. Most of my collection are in 256kb or 320kb MP3's.
While we're on the subject of music.
*rant on* Freaking basturds "borrow" my CD's and never return them. OMG, that annoys the heck outta me. *rant off*
*rant #2 on* Freaking new artists all suck. Why do they suck so badly? Someone give them some music classes. *rant #2 off*
I'll save the RIAA and MPAA rants for another time.
Originally posted by: Megatomic
Originally posted by: pillage2001
320Kbps......Have too much space in the hdd anyway. 🙂
Same here, but I use 256Kbps. HDD space is so cheap, why not have high quality MP3s?
AFAIK, VBR alt-preset standard actually yields better sound quality than standard CBR 256Kbps or even 320Kbps, while using less space most of the time.
That's the wrong attitude, you'd might as well not even encode your music because shrinking it down into a lossy format results in loss in quality, thus the lossy name. Lossless compression is a different story.
The point behind compressing to lossy is to get it down to a point where you're saving a pretty good deal of space 2x or more hopefully. Last I knew from my browsing around and doing some of my own tests, mp3 is easily the most popular yet outdated formats and thus is actually of low quality but because it is the most popular it has been "perfected" so that you can squeeze out the best bitrates and quality. VBR helps to achieve high bit rate performance when it is needed and low bit rate performance to save on space. Using CBR just seems somewhat silly to me (unless you've got an ancient mp3 player that doesn't support anything but CBR), if you're going to be using a lossy format at all.
Even if you only have 8 five minute songs for your 20GB player, if those songs have any slow portions or silent pauses, you're still going to be playing it @ 320kbps when there is no need for it because there isn't anything or enough there to hear. VBR is definately the way to go. Ogg, Musepack and even every lossless compression format I know of is VBR.
Last I knew, Microsoft has been pretty full of themselves, WMA is pretty good, but its nothing outstanding.
mp3 is the dog, old yet tried and true. Too popular for our own good, yet popular enough for its own good. It might never die and go away anytime soon, but at least its been here long enough to be "perfected" as I've already mentioned.
mp4 or AAC is better than mp3 (and probably better than WMA) per same bitrate and if it was "marketed" as mp4 it might be able to more easily replace it, but it isn't even THAT great. Then there's the whole mess of file names. It can be *.aac, *.mp4, *.m4a. I guess *.m4a is the best choice because it implies audio (a for audio) whereas *.mp4 can also have video...
Ogg Vorbis is probably the best competition for mp3, better in just about every aspect I believe Ogg is supposed to be the best sounding codec in the bitrate ranges most commonly used such as 128-192kbps (although ogg is variable bitrate only). Better sounding than mp3 and small enough for our portable players, it isn't a shock that many actually support this format, many but not nearly enough.
Musepack, now here's an interesting option. It isn't meant to be lossless, but it is meant to be the best sounding codec at high bitrates. > 192kbps average, as musepack is also variable bitrate only.
Lossless isn't only about sound quality you're going to listen to, its about storage. You have your lossless files and you can then transcode them to any lossy format you choose and won't suffer any nasty suprises down the road. If you use something like musepack, the files will sound very good, almost perfect, but if you transcode musepack to mp3 you risk poor quality files.
Portable players are still very finite, but with 160GB HDDs constantly on sale for < $50 with rebates, space is near infinate for lossless files. Codecs such as FLAC will reduce a full CD to around 250-480MB or so, while that is still alot it is better than copying the CD image (because you've got the files ready for conversion) and its also better than copying straight WAVs because formats like FLAC support tags (unlike WAV) which can transfer song data when converting to another format.
The problem with the codecs is subjective.
MP3 has great stereo, Ogg has poor stereo. The extra detail is coming from somewhere, and part of it is not having basic M/S JS.
Ogg has warm degredation, where MP3 can get harsh.
Musepack has very little support.
WMA is fine, but nothing special, unless compared to FHG MP3.
MP4 is like WMA, but a bit better (nice quality, but hard on batteries). Less support, overall, unless yo get an Ipod.
MP3 is the best for portable battery life, but not space.
Ultimately, FHG MP3 is the only wrong choice, and the rest are about what strengths you want.
Originally posted by: svi
I usually rip both to q7-8 Ogg Vorbis and 256kbps CBR mp3. Yes, that means I rip twice. I rip to FLAC and 256kbps CBR mp3 for stuff I figure I'll probably need more copies of, but I can't hear the difference between q8 Vorbis and FLAC, so I usually leave FLAC alone.
Why rip twice? FB2K and Winamp can both do transcoding easily and effectively.
i rip ogg quality 10, and transcode down to 5 or 6 to put on my portable. i backup flac to dvd in case i need it in the future, or want to quickly burn a lossless mix cd for a road trip or something of that nature.
A lot of this debate ignores a central premise - how the product is used. My MP3s all go onto CDRs for use in the car. VBR therefore is the logical choice - max quality with the most tunes on the CDR. I get about 8 to 8.5 hours of music on one disk - great for trips.
I always use the highest possible. I'm a quality freak.
Edit: This is off topic for MP3's but it has to do with sound quality ---> I've got a 5 gb's of Apple Lossless albums. That's about 4 albums haha.
