Originally posted by: d2arcturus
VBR
Hope everyone uses EAC and LAME, cause if you dont! :shakesfist;
exactly what i use.
192 VBR with Exact Audio Copy using LAME as the back-end for re-encoding.
VBR
Originally posted by: DaveSimmons
:thumbsup: I've ripped almost all of my CDs (roughly 1,000 so far) but that only took aroung 300 GB for the FLACs and another 100 GB for the MP3 copies.Originally posted by: Dubb
Lossless FLAC format on my music server.
Since it's lossless I can transcode to any MP3 bitrate I want for a portable, and change my mind as often as I like without any lossy-to-lossy encoding quality drop.
For my Zen Xtra portable I transcoded the FLAC to 192 kbps average VBR (LAME -aps -extreme) using dbPowerAmp's mass conversion tool.
Winnar. I use q7 vorbis though, there are many other codecs than do much better than MP3 for the same filesize.
edit: on the same note, my flac 750GB raid 5 array just passed 550 GB used :shocked:
I use human-powered mirroring so I have another set of drives in the closet with a second copy of the files. That seemed a little safer in case of something like a power supply explosion.
Originally posted by: FeuerFrei
I go for maximum bit rate. Quality is most important. I'm in no danger of filling my 20 gig mp3 player, so file size be damned!!
Originally posted by: pillage2001
320Kbps......Have too much space in the hdd anyway. 🙂
If you want max quality, then why are you still messing around with MP3's? I hate MP3's, so I go apple lossless all the way on my little 4 gig iPod.
Originally posted by: albumleaf
Anything below 192kbps sounds like sh!!t. I can't believe people can't hear the difference.
Originally posted by: Goi
Originally posted by: klah
LAME -> alt.preset.standard
same, but I use extreme
Same. Even when I didn't have decent audio equipment I could hear a difference, and I made an effort to download high-bitrate stuff on DIALUP. Downloading 128kbps on broadband is just disgusting.Anything below 192kbps sounds like sh!!t. I can't believe people can't hear the difference.
Because transcoding audibly reduces quality. If I didn't mind the lossy->lossy transition, I wouldn't encode at such high bitrates to begin with.Why rip twice? FB2K and Winamp can both do transcoding easily and effectively.
You mean >stereo? I wouldn't worry about it too much. Surround sound audio (actual surround sound audio, like DVD-A and such, not stereo audio being upmixed) is rare and just not that worth it. It's not that exciting to hear a clarinet or acid beat or whatever coming from exactly 7 o'clock. Distracting, really, which is probably why people don't bother with binaural music recordings.I'm ready for multichannel digital file formats. Anyone got recommendations??
No, transcoding does not reduce quality. FLAC is lossless. If you rip and encode to FLAC, then transcode to Ogg q8, you have the same result as if you encoded it to Ogg q8 when you did the CD ripping. That's why FLAC rocks, see. You need extra steps to make a CDDB-able copy, but you'll never again need to rip the CD for any listening or tagging purposes.Originally posted by: svi
Actually, MP3Gain adjusts the audio itself (but it is lossless). You end up with a MP3 file that is RGed, but has the necessary info to turned back into the original with no loss.Originally posted by: Jeff7Also, since FLAC has native ReplayGain support, the remaining MP3 files (albums I can no longer find) were either really loud or really quiet. So, I researched ReplayGain a bit. Fortunately, someone wrote MP3Gain, which adds a little bit of info to the ID3V2 tag, just a decibel level. A properly equipped player (I still use Winamp) sees this, and automatically adjusts the output level. Quite nice, so you can leave the volume slider alone throughout multiple albums.
When did I say I bothered to rip to FLAC most of the time? Never. You see, if I say I rip to Ogg Vorbis and mp3, and you say that I should try transcoding.. well, I'm sure you can figure out the rest.No, transcoding does not reduce quality. FLAC is lossless. If you rip and encode to FLAC, then transcode to Ogg q8, you have the same result as if you encoded it to Ogg q8 when you did the CD ripping. That's why FLAC rocks, see. You need extra steps to make a CDDB-able copy, but you'll never again need to rip the CD for any listening or tagging purposes.
VBR
Originally posted by: EglsFly
Well, I had been using 128K CBR for a compromise between quality and space. I had chosen this because I use MP3 for my car audio player (Alpine CDA-9847) with 700MB CDR discs, and my portable MP3 Player (512MB Creative MuVo N200).
After reading everbody's responses, I am thinking perhaps I should rip to VBR instead?
Although I am not sure if the MuVo supports it?
I use EAC with LAME, I noticed that EAC has different options for VBR.
Such as VBR 128K, VBR 160K, etc...
How do these differ if its variable anyways?
No, not misreading the RG stuff, but the MP3Gain stuff. From the MP3Gain main page:Originally posted by: Jeff7
Interesting; I guess I misread the writeup of Replaygain. I thought it stored just a bit of information in the ID3V2 tags, sort of like a +/- dB indicator. Interesting that it can adjust volume without quality loss.Originally posted by: Cerb
Either way, nifty stuff. Replaygain is definitely nice - many of my older CDs are very quiet, so you turn up the volume to hear them, and are then blasted by new discs recorded at high volume.
LOL, no. "Upconverting" can't magically restore information that has already been thrown away.Originally posted by: Bona Fide
I use 320kbps for all mp3's I get from online or wherever, but I've started to use Apple's Lossless Format for CD's. It sounds so crisp and it's as close to real as you can get. I'm thinking of converting my mp3's to AAF but idk if it'll work.
It doesn't work for camera images like they do on TV either. ("Can you enhance the detail on that license plate?" "Sure" (presses the magic add detail button))
Originally posted by: ArtVandalay
ogg-vorbis at setting 6, which is equivalent in size to 192kb mp3, but sounds better.
