Please comment on this system
Originally posted by: heresiarh
any pictures of the casing?
Of mine? You should use the quote function. 😛 😉
There are pics in that "Read my review" link in my sig. It's like 6 pages long.
i'll check it out right now. By the way, I like the look of the coolermaster casings.
Be aware that server/workstation motherboards often have a "footprint" that won't work in just any ATX case. I'm not positive what the depth of the Coolermasters is, but I can tell you that a Tyan Thunder-series board definitely wouldn't fit my Lian-Li. So check up on that if you have visions of dual-Opteron goodness dancing in your mind. 🙂 AFAIK the Antec PlusView1000 that I put in my wish list has the necessary space and clearance.
Is a Burger King Whopper worth buying, or grille your own? 😀 If you need a pre-built hamburger right away, get a Whopper. If you want the satisfaction of a home-grilled burger just exactly to your taste... 🙂
but, point noted. come on people, not a single soul from chicago? i will pay to have a system built since i dont have much time these days.
It takes about an hour at most to build it. That's if you've never done it before.
i did it once with my current system but had some technical issues, i don't think i have the patience anymore to do it.
The only thing I like about alienware systems is the casing, i was hoping if i could call alienware and just buy a kick ass for decoration !!🙂.
Any advice on nvidia quadro cards?
Originally posted by: ForceCalibur
No, I'm not saying you should throw the 9600XT out the window. It is a middle ranged card, that costs way too much for it's performance. You spent 140 dollars, but you could have spent 140 dollars shipped on Ebay and have purchased either a 9800se, 9800NP, 9700Pro that absolutely KILLS the 9600XT.
This is pretty much true for all 9600 series, they all suck for their price. A geforce 4 TI series card performs equally as well, and it can be bought for 40-60 dollars shipped here at Anandtech's very own F/S-Trade section. Ebay as well.
The 9600XT CAN be bought for 80 dollars. I saw one go just last week on the FS/Trade forums. These are people who are knowledgeable as to just how poor the performance/price ratio is for this card.
i have a geforce 4 ti card and a 9600xt and a 9800 pro
the geforce 4 ti card is sittin on the shelf,both the 9600xt and the 9800 pro
BLOW it out of the water.
And coincidentally the one you make yourself wont be made out of monkey meat 😉
Theres more parrallels to that analogy that meets the eye 😛
