Petition to make USA Metric
pmv
15,142
10,041
year/month/day is the "correct" form. "Bigger" numbers go to the left. Years are the biggest. It also makes sorting easy for computers.
Or you can go month/day/year, which also matches how American people commonly say dates as in September 5th, 2005.
Guess I should say "FTFY" (this terminology doesn't come naturally to me!)
Elsewhere its more common to say 5th of September, 2005.
Imperial vs metric is an entirely subjective thing and both systems have their merits, but the US method of writing (and saying) dates is a trifle illogical.
Possessed Freak
6,045
:rolleyes: Get it in your thick skull that not every single person is good at doing math in their head.
DERRRRRP.
Your earlier statement: "you're not in a position to start pulling out a calculator and figure out if 43/24" is bigger or smaller than 3/5" etc."
If you don't know if 43/24 is bigger or smaller than 3/5 I can't help you. Further, if you don't know why this should be one of the easiest comparisons relating to division then perhaps you need a refresher of numerators and denominators. Hint: The numerator of the first example is LARGER than the denominator.
How about that whole metric is more accurate bullshit? Care to explain how that is even possible or are we just going to sweep that under the rug?
lxskllr
60,424
10,809
Retard units are a large reason architectural plans never work. With fractions you end up with bits and pieces left over, and stupid shit like 16' 7 11/32"+ Plus what you fuckin' asshole?! If your plans start off wrong, nothing will be right. Everybody inserts error into a process, but you need a solid baseline to keep track of, and mitigate error. Retard units add error for no good reason.
Aikouka
30,383
912
Gee, I'm sorry - I didn't think typing the answer in would matter, since then you'd just, "well, you probably googled it."
Why would I do that? It would be silly of me to even ask if I didn't think anyone could do it.
I don't really have a side in the whole metric vs. standard debate. I really couldn't care less. Well, actually... I'm kinda lazy, so I don't really feel like having to force myself to use metric. :p Anyway, I was mostly just trying to show how most people probably don't know fairly standard/basic conversion factors of the standard system since easy conversion factors is probably the nicest part of the metric system. For example, how many people do you think know how many feet are in a mile?
Then again, with people purchasing all those margarines and spreads that come in those big bowl things - it's possible that some people don't see this frequently. And, they've missed out on the taste of real butter.
You can buy nasty margarine in those sticks too. :p
jagec
24,442
I can't believe so many people are actually defending the Imperial system in this thread. It's indefensible.
Drako
10,697
161
Just out of curiosity, how do you order lumber in metric countries.
If I go the the lumber yard looking to by some 8' 2x4s, and some 4'x8' plywood, what do I ask for?
nehalem256
15,669
8
1/32in is more precision than a mm. Are you saying construction is done to more accuracy than a mm?
lxskllr
60,424
10,809
I expect mathematical perfection on plans. If you can't get that, nothing will be correct. Individual measurements don't matter as much as cumulative, and it takes thousands of parts to come together to make a whole.
MadScientist
2,186
63
OP,
Yes, it's been tried. Congress passed the Metric Conversion Act in 1975. It didn't work. It was amended in 1988, but conversion in the private sector, while encouraged, is voluntary. And that's the problem.
http://www.nist.gov/pml/wmd/metric/upload/1136a.pdf
The scientific and medical communities use the metric system almost exclusively.
In my chemical research lab we use the metric system, but when I scale products up for production I have to switch back to United States customary units, pounds, gallons, etc. All our production units use instruments and scales calibrated for pounds and gallons.
I have no problems switching back and forth since I use the metric system so much. It's like learning a second language. You think in both.
So to totally convert to the metric system we have to teach it in our schools and force students to use it and/or force the private sector to use it.
A gradual conversion has/is being tried and it's not working.
lxskllr
60,424
10,809
The load of crap that construction needs to measure to less than mm accuracy.
Ah, I see, it's reading comprehension that's at issue here. I never said it had to be measured to the mm. I said it had to be computed exactly, so you don't end up with a clusterfuck at the end. If you don't start off right, it won't be right, and errors are harder to track since you don't know what it was supposed to be in the first place.
Train
13,591
87
www.bing.com
Explain to me how an imperial system cannot be computed exactly. Both systems use the same mathematical system.
You are completey blowing shit out of your mouth.
lxskllr
60,424
10,809
You tell me. I already gave an example of architects making up numbers because there isn't a fraction that works. Maybe you can also tell why there's never been a building drawn that closes on itself. It /can/ be done, somehow never is when fractions are involved. It's a complicated abstraction that lends itself to error.
Train
13,591
87
www.bing.com
There is no rule that says you have to use fractions. You seriously have no clue what you are talking about.
MadScientist
2,186
63
Since, i.e., a 2x4, is actually ~1 1/2" x 3 1/2" there's a problem with soft or hard conversion (see the article).
The article states that there is little incentive for the wood industry in the US to change to the metric system.
http://www.awc.org/helpoutreach/ecourses/MAT120/MAT120eCourseV08-2004.pdf
http://diy.stackexchange.com/questions/444/what-are-framing-dimensions-like-in-the-metric-world
lxskllr
60,424
10,809
Yea dude, I'm the one without a clue. You go find some architectural prints, get someone to explain them to you, and then you might be able to come back and add something to the discussion. Until then, I suggest you just read and learn.
Train
13,591
87
www.bing.com
Or... you could just answer the question.
