Discussion Performance Efficiency Score using HandBrakeCLI
19,219
If we could get the same data for average frequency of P and E cores we'd have it all during the run we'd have it all with no chance for human error!
Unfortunately, that's something more up Boris's alley. There might be a way to expose that information through openhwmonitor library but I have no idea how.
19,219
It would still remain interesting to know for sure 😀
If you are feeling bored, you just need to modify the script "scripts/mingw-w64-build" to use the latest Clang and then compile HandbrakeCLI.exe for us on one of your Linux machines :p
Build instructions: https://handbrake.fr/docs/en/latest/developer/build-windows.html
I know, that sounds like something a boss would say, with absolutely no idea of the effort involved :D
19,219
The easy way doesn't mention the Geekbench 5 prerequisite. When I go to download 5, I am taken to the download page for 6. Found the old version here: https://www.geekbench.com/legacy/
My easy way is not for running Geekbench. Only for HandBrakeCLI. That's why I'm showing only the Begin Encode option.
Didn't remove the other options from the Powershell script because I don't want to deal with things not working due to removing the wrong block of code. So while you can enter some number other than 3, it's not supported in my mangled PES :D
The original PES thread is this: https://forums.anandtech.com/thread...-efficiency-of-x86-cpu-architectures.2597905/
Sgraffite
208
145
It seems to require Geekbench to run if I enter the number 3. Or maybe not, I was just hitting enter and though that meant 3?
Hulk
4,128
So 9800X3D is performing at more than twice higher rate than 9950X. Could this be due to V-cache?
@lightmanek , if you get the time, can you disable one CCD and see what score you get?
I think the 9800X3D is just slightly more efficient than the 9950X. 171.5Wmin for 9800X3D and 192.9Wmin for the 9950X3D.
Reactions: lightmanek
19,219
In munching mode at the moment but I was able to update the openhwmon DLL.
Only took downloading like 20+ gigs of VStudio, googling to find Arrow Lake CPU ID, updating the CPU.cs file, mimicking what Boris had done for the Raptor Lake entry and Build.
Reactions: Elfear
19,219
Arrow Lake and Lunar Lake users can now benchmark their CPUs using the EASY way (URL updated in first post).
Wanted to see how it would do with Jellyfish so renamed the file to video.ts and:
Seems to like Jellyfish more :)
19,219
Meteor Lake and Panther Lake support added to the DLL.
@511 , would you like to give the benchmark a go, with High Performance power profile, HT on and off? It's really easy and quick to run (download/instructions in the first post of this thread). And you could try the Jellyfish encode too if you want to contribute more.
@Schmide , interested in contributing the score for your Ryzen laptop?
Reactions: lightmanek and 511
511
5,517
4,909
Sure I am away for few days but I would love to do it once I get back
lightmanek
524
1,292
I've tried today, but my PC just doesn't boot when I try to disable CCD1. Tried 3 times and I give up as I have limited time this weekend to spare.
Sgraffite
208
145
Possibly, I am using 25.2.0.3 which is probably latest as I just installed it. I thought maybe a divide by zero or something, but that is just spitballing.
