Article [PCGH via Neowin] PCIe 3.0 could be crippling AMD's RX 5500 XT performance
Hitman928
6,750
12,479
PCGH is the source of the benchmarks but since it's not in english, I'm linking a write-up on the findings as well.
This story popped up in my feed, not too sure what to think of it yet and don't have much free time to really dig into it but very interesting if true. Possibly could be a driver issue at work? I don't know, it seems like PCIe3 8x shouldn't be this restricting but maybe it is.
Shivansps
3,918
1,570
AMD did not cheap out anything, these RX5500XT are actually RX460/RX560 replacements, that also had a x8 PCI-E link.
What is actually wrong is that AMD attempts to sell these as a RX580 replacement.
They also forcebly removed PCI-E 4.0 support from non x570 boards and has been half a year with no replacements in sight. So... you want to fuly use a RX5500XT 4GB? buy a x570.
Golgatha
12,424
1,110
There's no story here. These are heavy VRAM games performing better when the 5500 XT's 4GB of onboard VRAM is exceeded. The game is having to swap textures to system RAM and the interface to system RAM then becomes the bottleneck when transferring data to the video card. This is exactly analogous to when programs fill up system RAM and your HDD/SSD/NVMe drive becomes the performance bottleneck because that's where the swap file for system RAM resides.
Guru
830
361
I think he meant 5500XT 8GB vs 5700.It's odd that 8GB indeed gets benefit from PCIe 4 while 5700 doesn't.
Its not odd at all. RX 5700 has all pci-e lanes in it. The RX 5500 DOESN'T, because of a cost cutting decision by amd. RX 5700 therefore performs exactly the same at pci-e 3 or pci-e 4.
Again its only the 5500xt that doesn't have full 16x pci-e lanes due to AMD cutting 8 of them for cost savings reasons. Reason why pci-e 4 performs better is because even at 8x pci-e it has the same amount of bandwidth as pci-e 3 16x.
PhonakV30
987
378
Here you go :
at 4K settings , different between PCIe 2.0 and 3.0 is 1% but 5500XT 8GB , It gets more than 1%.average is around 5%.
The Point is that , this card does have 8GB and PCIe 3.0 x8 mode ( aka PCIe 2.0 x16 mode) and Benchmark shows it gets better fps up to 10% , This means even at PCIe 2.0 x16 mode still needs to swap textures to system RAM But I don't see this absurd thing in 5700XT If you set to PCIe 2.0 x16 mode.
VirtualLarry
56,587
10,225
That's why I suspect that the issue is some sort of driver "pacing" or otherwise, latency-related issue, when transferring data via PCI-E DMA to/from the GPU's framebuffer. I don't think that it's down to bus bandwidth alone, otherwise, why wouldn't we see it with the RX 5700(XT) in PCI-E 2.0 x16 mode?
NTMBK
10,498
5,966
Bear in mind that AMD's own laptop chip only has x8 lanes for the GPU. It's a power optimization as well as a cost reduction.
Thunder 57
4,234
7,012
I recently noticed my GeForce GT 730 is PCIE 2 x8.
When these PCIE x8 GPUs get put on a expansion card, the fingers are still x16 length. [A real PCIE x8 card] So, they don't gain motherboard compatibility. :confused: Board partners lazy? Buyers think x8-length card is inferior?
I don't think I've ever seen a PCIe 8x slot. Heck, these days it seems to all be x16 and x1.
