Oh dear... 74C on my Cel. D.
Zap
22,377
7
GAH! Tried to reply earlier, had stuff typed up and then forum stopped responding. :|
Originally posted by: VivienM
2) So what 92mm fan to get? I haven't found too much available around here that's an improvement over the 27CFM 21dBA fan in there now...
4) Based on your experience with the same motherboard and cooler (and similar CPU type), would you conclude that I applied it wrong? or would I be wasting $20, time, and the risk of breaking something by redoing it?
5) So what happens if it gets too hot? Mobo kills the power, end of story?
6) Hmm... wonder if that's what's going on here?
2) I recently got this Antec 92mm TriCool fan that I'm pleased with. I also have this Panaflo 92mm "M" fan that pushes lots of air with a lot of "whoosh" noise, could be slowed down plus there is a slower "L" model. If you believe their ratings, this Thermaltake 92mm Silent Cat fan gives 52CFM at 21dba. I also have one of these, came with my Thermaltake Silent Tower. It was anything but silent at full speed, but is fairly quiet at lower speeds. The thing is that fan manufacturers seem to each have their own methods of measuring performance so it is really difficult to compare fans by just using their published numbers. The thing is... how quiet is quiet enough for you? I'm personally a fan of quiet computers. Compared to all my RL friends my systems are completely inaudible if their systems are running in the same room. In any room with background noises (for instance desk fan or A/C, or people talking) I do not notice my systems running. However, I do not dare put myself in the same category as those frea^H^H^H^H enthusiasts at SPCR because while they seem to not tolerate any noise whatsoever I'm content with quiet enough to not hear under normal conditions. BTW, a friend of mine had some 80mm Vantec Stealth fans and though silent, they didn't feel like they were moving any air. The other thing about noise is that even fans which do produce noise can produce a different quality of noise. For instance, when SPCR tests a fan undervolted they will report on bearing "clicking" noises because some fans produce it and some don't, and it bothers some people but not others. Some fan motors make a high pitched whine. Some fans just sound like the "whoosh" of air. I've personally concluded that for my own purposes any decent fan will be quiet enough with a speed controller, and larger diameter fans will always push more air than smaller diameter fans - all else being equal.
4) If you're confident that you only applied a thin layer of compound, then I think paying for AS5 and reapplying compound will be a waste of time and money. If you want to spend time and money and really want low noise with better cooling, may as well sell the Zalman 7000 cooler and get something better. You'd probably get a much better gain off swapping to an XP-90 heatsink with decent fan with the same Zalman heatsink paste over keeping the Zalman heatsink/fan and getting AS5.
5) If it gets way too hot, power cuts and you'd experience a system lock. I've seen Intel systems (P3 and P4) lock due to heatsinks falling off. Don't recall ever seeing a CPU die from that. The P4 at 3GHz+ have a version of SpeedStep which cuts multiplier down to 14X, making an unoverclocked CPU into a 2.8GHz chip. There is another feature of the P4 which is throttling - been available since... maybe since the first P4 Willamette. This feature cools down the CPU by switching it on/off. People think it reduces clock - effectively it makes your system slower but clock stays same. What happens is that in tiny increments probabaly measured in nanoseconds, the CPU switches from FULL SPEED to COMPLETELY STOPPED and back to FULL SPEED. The percentage of time CPU is stopped is usually somewhere from 20% to 80% and I think can be controlled by BIOS. This is kind of like a fan speed controller that uses PWM - instead of a fan being UNDERvolted, the fan runs at FULL voltage, but not all the time, instead full voltage is pulsed in fractions of a second coupled with no voltage. End result is fan runs slower. You can't tell, unless you have an LED fan (as I recently found out :p ) and you get a nice strobe light effect. Oh yeah, plus the PWM controller doesn't get as hot. Back to the CPU throttling - typical benchmark and measuring programs wouldn't report the throttling because they can only make measurements while the CPU is in an ON state and not OFF state, and since when in ON state CPU is running full speed, software will report full speed. I think that's why throttlewatch software was made to be able to report throttling. While your Deleron (word I coined last year on these forums to mean Celeron D) doesn't do SpeedStep, it should support throttling.
6) Lots of complaints when the IS7/IC7 boards came out and reported much MUCH higher temperatures than competing brands. A bunch of complaints and finger pointing later, Abit released a BIOS update that lowered reported temperatures, though temperatures still reported higher than other brands. Abit still claims they are generating "proper" temperatures based on Intel guidelines. Users have found that regardless of temperatures, the same CPU feels the same temperature to the finger whether on an Abit board at 50º or another brand at 40º.
Of course I could be totally wrong... spending too much time on forums will do that to a brain...
VivienM
486
45
Here's the bottom line...
I started out with the stock HSF running at 5270RPM and being about as loud as a vacuum cleaner. After months of that, I finally got fed up, hence why I got the Zalman. Since I thought, perhaps incorrectly, that 75C was the throttling temperature, I started to get worried my Deleron (cute name :)) hit that figure. Since I took the Fanmate 2 out (well, it's still in there, but not hooked up to anything), the max temperature I've seen is about 72. That's doing hardcore transcoding - normal temperature while watching TV, for example, is a reasonable 59.5.
Is the thing noisier that ideal? Sure... but let's be honest here. After fixing the Deleron noise problem (stock HSF at 5270RPM was probably 45+ dBA, based on SPCR tests, while the Zalman at full blast is 27 dBA... need I say more?), the noisiest system in here, by far, is my dusty 1.9 Willamette P4. That thing needs a good cleaning, and replacing the two noisy 80mm fans with Vantec Stealths or something else that's quiet. And maybe Arctic Silvering it up, too (there were screwups when I installed the HSF almost 4 years ago that make me believe the thermal pad is less effective than it should have been)... which I would do if I bought the AS5 for the Deleron.
And I want to replace the 1.9 (which would stay around as a secondary system...) with an Athlon X2, too... which requires lots of money.
So, at this point, I'm not particularly willing to put any more money into the Deleron (which also needs a second TV tuner...), unless it's necessary for it not to melt on me in a month or two... My current noise reduction strategy is to attack the noisiest thing first, and the Deleron isn't winning that award anymore :) If the Deleron can last a good 4-5 years at this heat level, or until it wins the noisiest system award again, then I'm happy enough.
As for the BIOS upgrade, do you remember what revision it is that fixed it? Perhaps I should upgrade mine... as that's a relatively costless thing to do. :)
Zap
22,377
7
"Wins noisiest system award" LOL! I like that.
Just make sure BIOS is recent, as recent ones have all the "improvements" of older ones... usually.
zagood
4,102
You hook up the AS5 yet?
Just remember, any temps you can reduce without fans means a) extending the life of the components and b) you can run the fans slower, aka quieter.
-z
VivienM
486
45
*sigh* I really don't know what to do on this one... I'll probably just end up buying the AS5 and redoing both my boxes, but... if the temperature drops by less than 2-3C, it will have been a lot of effort/expense for not much.
INM8
274
Has anyone heard of this?
Silenx 14DBA Silent Case Fan 92MM 1800RPM 36CFM 3/4PIN
14DBA, 36CFM? Sounds tempting... but horribly expensive.
...i dont have time to explain now, but i will recommend that you DO NOT get these fans. I almost made the same mistake.
VivienM
486
45
Okay, I went to the computer store... came back with AS5 and the cleaning thingy...
VivienM
486
45
Okay, so I installed this now... first thing after installing, boot into Windoze (remember, the thing runs Linux normally) and do the BIOS update. Reboot after that... OMG, 78C in the BIOS.
Turns out the fan cable was caught up in the fan, so it wasn't spinning. Oops. Fix that. Boot again.
I'm staring at the BIOS now, it's reporting 50C system temperature. This, of course, is with the side of the case still open...
Now, time to decide whether to plug the Fanmate 2 back in or not...
VivienM
486
45
Okay, thing is closed up, booted, and whatnot...
temp1: +35 C (high = +4 C, hyst = +3 C) sensor = thermistor
temp2: +48.0 C (high = +85 C, hyst = +80 C) sensor = diode
temp3: +40.5 C (high = +95 C, hyst = +90 C) sensor = thermistor
Did the BIOS update or the AS5, or both, lower the temps, who knows... I'm inclined to suspect the AS5, though.
VivienM
486
45
At roughly full CPU load (compiling kernel):
temp1: +39 C (high = +4 C, hyst = +3 C) sensor = thermistor
temp2: +59.0 C (high = +85 C, hyst = +80 C) sensor = diode
temp3: +47.0 C (high = +95 C, hyst = +90 C) sensor = thermistor
VivienM
486
45
After extended idling...
temp2: +46.0 C (high = +85 C, hyst = +80 C) sensor = diode
temp3: +38.0 C (high = +95 C, hyst = +90 C) sensor = thermistor
11-12C less than before? How... strange.
VivienM
486
45
And after idling two more hours...
temp2: +45.0 C (high = +85 C, hyst = +80 C) sensor = diode
temp3: +37.5 C (high = +95 C, hyst = +90 C) sensor = thermistor
How low is this going to get?!?
Fallen Kell
543
It takes about 24-48 hours for the artic silver to fully work correctly. It is on their website somewhere or another....
cmv
3,490
I've got a Celeron D 340 on an Asrock P4Dual-915GL for MythTV:
temp1: +37 C (high = +115 C, hyst = -17 C) sensor = thermistor
temp2: +28.0 C (high = +80 C, hyst = +75 C) sensor = diode
temp3: +69.0 C (high = +80 C, hyst = +75 C) sensor = thermistor
That's with AS5 and the side door off. Unfortunately, I brought a heatsink & fan combo locally and it's very loud and lm_sensors can't set the fan speed :(. At least it appears to be working well. I thought the stock 3.0 Ghz or less P4 heatsink would be a good buy but now it sounds not so great.
There is a chance Asrock didn't hook up the fan speed inputs but there may also be a bug in the BIOS/lm_sensors so I'm opening a ticket w/ them.
