Originally posted by: Zap
I used to run a Prescott 2.4A on an Abit IS7 overclocked to around 3GHz with a Zalman 7000AlCu (non LED). Load temps were well into the 80ºs Celcius. A few thoughts for your situation...
1) Cleaning cable clutter always helps.
2) How cool the CPU is depends on how cool the air is inside the case. If the air gets too warm in your case, the best air cooler in the world won't help. I think part of the problem is the Vantec Stealth exhaust fan. My suggestion would be to get a 92mm fan as suggested by someone else and use a fan speed controller on it to get the desired noise/performance balance. You can use the Fan Mate included with your Zalman because...
3) The Fan Mate included with your Zalman reduces the speed of your fan by a bit even if it is turned up all the way. If you plan on using the fan at full speed, don't hook up the Fan Mate.
4) I've found that proper application of heatsink compund to be more important than the actual brand/type of heatsink compund you purchase.
5) I don't think the Celeron D does any throttling. The Pentium 4 Prescotts do that, but only the ones 3GHz and up.
6) Abit motherboards seem to report temperatures higher than other brands.
Okay, so if yours went into the 80C range, and mine (2.66GHz, less cache) is around 72, then does that mean I'm actually not doing too badly?
1) I've tried my best... the thing has rounded cables, too, for HD (yes, I should have gone SATA...), optical drives, etc.
2) So what 92mm fan to get? I haven't found too much available around here that's an improvement over the 27CFM 21dBA fan in there now...
3) That's why I removed it...
4) Based on your experience with the same motherboard and cooler (and similar CPU type), would you conclude that I applied it wrong? or would I be wasting $20, time, and the risk of breaking something by redoing it?
5) So what happens if it gets too hot? Mobo kills the power, end of story?
6) Hmm... wonder if that's what's going on here?
