System video memory power has three phases.
It is also worth mentioning the BIOS switch button. By default, the primary BIOS has elevated relative to the reference frequency 1000/1450 MHz for core and memory respectively. But if someone has such a performance may seem a little, there will be a single switching frequency grow up to BIOS and 1150/1500 Mhz. Such a threshold frequency plant really impressed me.
Of course, it's worth noting Sapphire and for originality place branded Black Diamond chokes, which are double-sided and very cool look. To my mind, this is the first experience of such location chokes.
Increased frequency of the graphics core and video RAM, of course, require high-quality cooling systems. Here at Sapphire also okay.
For the removal of heat from the GPU is the copper plate heat sink with heat pipes. And for dissipation of heat from the memory of the Sapphire uses thick enough termoprokladki, which, in my opinion, really tolše conventional.
Rear plate, as well as radiators supply circuit, also received the same thick termoprokladki for the dissipation of heat.
Jacket cooling system is notable is not allocated.
Radiator cooling system has four heat pipes that transfer heat to aluminum ribs.
Applied in practice, the decision on a common space for the dissipation of heat from the GPU and memory, it was quite successful, but more on that talk just below.
Test stand:
-Intel Core i7-2600K;
-Corsair Dominator RAM GTX2 2250 Mhz 2 x 2 Gb;
-motherboard ASUS Maxsimus IV Extreme_Z;
-solid state drive Corsair Force 3128 Gb;
-power supply Corsair AX 1200, 1200 Watts.
At 1.27 in graphics card
Sapphire HD 7970 Toxic in benčmarke could make stable 3DMark11 at 1300/1900 Mhz frequencies. Remember that earlier I mentioned the four maps?
So, calling the Smoke to boast my high speed, it denies me sosbstvennymi from the other three cards. One card having frequency 1300/1920 Mhz and two other razognalis′ until 1280/1850 Mhz. In my opinion, for air cooling and taking 6 Gb of video memory is impressive.
