Hmm, isn't this the phantom card that was supposed to be clocked at 1335 Mhz... that all the AMD cheerleaders were quoting and trying to reference when mentioning 7970 overclocking? 1150 Mhz stock is not quite 1335 now is it... And 1300 at 1.27V is not quite stock either...
Woot 12 gigs of video memory
I thought games had a 32bit memory ceiling?
tks for correctunz was unawares
are you suggesting that games can only address 4GB of video memory? because that's not at all how things work
if anything a 32bit game will be limited on how much system memory is used, not video memory
It's not exactly a stock cooler either. TPU news further down has announced a 1200mhz gtx 680. You can call that it's stock cooler if you want ?
I thought addressing memory period was limited?....whether or not its system or video!
That's correct, however it doesn't apply to all the memory a video card uses.
IF you have 4xMSAA, for example, you're taking 4 samples per pixel, and must store 4x as much information as with no AA... however the game only needs to know about the final result.
Really, most of a game's address space is textures. I think the memory explosion happens mostly completely localized on the GPU in areas of memory that are not addressed by the game itself, and therefore not subject to a 32 bit addressable space limitation.
What does 1.2Ghz (base and boost) mean?
6GB
bwahwhahwahwahaha.
I'm sure Vega and the other 5 people running 5x1600p in portrait mode will give a ^&#@.
Monster card. They should sell it @ $549 tops
Wondering if the so called Atomic will ever show up...
Not sure I understand why you came into the thread and spewed this uninitiated. Bottom line... The card kicks butt.
