Originally posted by: Kiyup
If they can be resurfaced, have them resurfaced. Replacement is a waste of money.
I agree. And, it's not expensive to have it done either. Like $10/a piece. AutoZone I know does it. Most parts stores can either do it or have it done.
Originally posted by: Ornery
Are you installing these? Napa has budget rotors, same price as Autozone's cheap ones,
for $27.00 for your car. I just put some on my wife's car, and they're fine. If they give me
any trouble, which I doubt, I've got a one year warranty. It's worth taking the chance for
that huge price difference. Lube the slides, and use the paste form of 'Disc Brake Quiet'
I know you wouldn't be asking about turning them, if you weren't trying to save a buck.
I went with ultra cheap pads, too. WTF, they can be reinstalled in a flash, if they're no good.
Again, huge price difference makes it worth it.
2000 maxima!Originally posted by: Ornery
Actually, I'm not sure what car Skoorb even has. I checked for a 1999 Maxima.
Originally posted by: tnitsuj
Are you sure that big hub nut is actually holding the rotor on? Have you tried just yanking the thing off? The bolts should only be neccessary if the thing is really siezed on there.
That is a spindle nut and hold the CV joint to the spindle. It has nothing to do with the rotor. That mess's up a lot of peop;el that try and do their own brake job. Trust me, I had a car towed to me missing the spindle nut and the customer complaining that the rotor still will not come off. 🙂
Awesome link there. The socket wrench is loosening the 'torque member' here.Originally posted by: tnitsuj
http://www.motorvate.ca/mvp.php/300
This guy tells you exactly how to do it. Apparently, Nissan uses something called a torque member that may or may not be holding the rotor on.
Originally posted by: Skoorb
Based on comments here and that motorvate.ca it does indeed look like that huge ass nut should not be touched by me 🙂 busted.JPG <- that is a pic of the broken bolt/stud. Ornery, is it easy to replace? I figured it was a major part of what was going on, but then since I can't take the rotor off yet anyway...🙂 I will try the mallet with more strength tomorrow when it's not late, but I really can't do it right now 🙁
Yeah I got that part off. It was the rotor that was stuck :QOriginally posted by: Ornery
Come on Skoorb, wrestle that thing off like a man! 😛
Yeah, I was assuming that the rotors were warped and not just in need of new pads. Honestly, most of the time if you're just replacing pads and nothing has gone wrong you shouldn't even need to re-surface the rotors.Originally posted by: se7enty7
Here's the thing. If you are only replacing pads then get your rotors turned. Rotor's last longer than pads for sure. If they are warped then buy new ones.
imo.
