- Sep 29, 2000
- 70,150
- 5
- 0
QUICK QUESTION: I am re-greasing the slider pins. I was told that dialectric grease is fine. I have some stuff that I bought from advance auto parts and it is dialectric spark plug stuff. It says it's for spark plugs on the tiny packet it came in, but is this the same dialectric stuff that a person could use on slider pins, or are there different dialectrics? Thanks!
Maxima is throbbing (like my big - ), so I need either new rotors or the existing ones resurfaced. OEM rotors, which I'd need to buy, will be $80/piece. Where would I get them resurfaced, and is it really worth the effort? I'll be buying new OEM pads eitherway at $58 for the pair.
*EDIT* OK I was about to take the rotors off and realized that I can't because firstly my bolts I bought are not quite big enough. I bought 8 mm 1.25 pitch metric. Honestly, even in my haynes, I can't find what it's supposed to be. Can anybody guess from that pic? Also, there is a whopping great bolt holding the damn rotor on. What size is that likely to be? It's definitely bigger than any that I have in my socket set
Here is a pic of the condition of the front left rotor (some of those markings are just dust).
You'll note that one of the bolts holding the damn wheel on broke off as I was trying to unscrew it. Reason? It was threaded badly. Why? Because whomever put on my tires rushed the job months ago, so now I'm down to 4 bolts holding that wheel on.
