professorman
- Feb 24, 2009
- 33
- 0
- 0
Arggg. This is really frustrating. It is expressing symptoms of temperature related, however all my temperatures seem normal. I run HWMonitor and all of the temperatures seem normal. GPU is about 55 degC. And my CPU temps are around 29-41DegC.
When I turn on my computer for the first time this evening, it ran fine, the. After about 15 mins it cut off. I turns back on and ties to boot, but won't even get back to windows before it cuts off again. I tried several times and the same thing happens each time. I then let 20 minutes pass, and I try again. This time, it works, I boot to windows. I was able to use the computer for about 3 minutes, checking my temperatures with HWMonitor, everything looks normal, then it cuts off again, then back to booting and cutting off. Essentially, the longer I leave it, the more usage time I get out of it before it cuts out
Could this be corrupt memory? I pulled all my memory sucks yesterday and it worked after that, then I reinstalled them in pairs and it continue working.
My CPU is water cooled and I have 6 fans in the case, and I don't over clock.
