- Nov 14, 2013
- 37
- 0
- 0
If it fails again, I will let you guys know. Even though after this I would be stumped!
Yep my problem still exists. However I do not have a new power supply I can test out.
It has to be the power supply right? I mean that is what is making the clicking on and off sounds.
The way I was able to get it back just now was to unplug the 1 psu cable that runs to my hard drives not sure if it was the ssd or hdd, but the lack of powering 1 more thing helped it boot.
I am not sure what you want me to test, after I got it running it crashed on me again while browsing the internet. So again I removed that one psu cable and it booted, it gave me an overclock failed message but I am thinking that is irrelevant, because I did downclock it. It also wasn't the first time I saw the overclock failed message. If it was an overclock failed clear cmos would fix the boot cycle and it doesn't. I am pulling the psu cable for my two ssd in raid 0 though.So can U test things next by removing the power cables from the drives one at a time?
Amazing, but it does again, now, look like a PSU issue despite what a beast yours is. Well, to me, it is. I guess, beast is subjective.
Ever think of using REVOSLEEP to put yr backup drives to sleep? Yr mechanical one, which, I would think draws more power, especially. But I think it's not compatible yet with W8....assuming U R running it.
Edit: Jus looked, yes U R....8.1 64.
http://revosleep.realspooky.de/
Yep, only still compatible with 7. Just another of infinite reasons I will go on running 7.
I think Virgorising hit the nail on the head, but I too am surprised by the excessive power needs. ClutchAutomatic, did you ever see power requirements listed for your water cooling unit? I did some searching the other day and found nill.
Okay, but the thing is it shouldn't be stressing this psu! Next time it crashes I will try to pull the other HDD cable.
It crashed but was able to boot back up with no errors this time.
Yeah I didn't change anything, I just came back and I was at the log in screen so I know it turned off. I have the GPU on 2 rails as well. 2 ssd on 1 rail, 1 hdd on 1 rail, and the corsair pump on 1 rail. CPU on its own rail and same with motherboard.
I am running sleeping dogs, been about 30 minutes now and no crashes. If I pulled the power ribbon from one ssd I might be able to get past the bios but it won't load into windows. So I am trying to get my computer to fail again.
definitely the GPU, I don't think the cooler is pulling that much power.
