- Nov 14, 2013
- 37
- 0
- 0
Got to bios as soon as I was able to unplug ssds
Corsair H100i closed loop liquid cooling.
O! Well, that is excellent! But now, I am more confused than ever re yr symptom. Cept still might be the PSU.
.... I was able to back up my steam games to my HDD about 32 gigs and it did so flawlessly. But who knows when the next crash will be.
So I crashed again while running bf3. Could be heat issues now I am getting worried.
When the computer is trying to boot and crashing the corsair h100i light is flickering.
Excellent videos. Was that before or after you tried unplugging the SSDs? Are you monitoring temps? If not yet, I would do so.
I tried unplugging the ssd's after this video and still not able to boot.
Just now switched the power supply cable that runs to the pump and I got it to boot.
The pump was plugged in the end of the the line of the 2 SSD's. So now I have 3 of these cables, 1 for the corsair pump, 1 for the 2 ssds, and 1 for the hdd.
Hopefully this helps out now.
+1 and also.the cooling system might have a air pocket.so every time the air get's to the pump the flow stop.If the pump is failing, you'll likely see temperature spikes right before it crashes.
Soooo smart! R U saying the pump wasn't receiving full power and so, was faltering and shutting down?
That is what I am hoping for! Not enough power for the pump so it safely shuts it off is what I am thinking. Those samsung 840 pros must be some heavy hitters.
