- Nov 14, 2013
- 37
- 0
- 0
Computer specs
CPU: Intel i7 3930k at 4.5 @ 1.325
Motherboard: ASUS Rampage IV Gene
Ram: 16 GB CORSAIR Vengeance Pro @ 1600mhz
Graphics Card: MSI GTX 780 Lighting
Hard Drive :2 Samsung 840 Pro 256 in Raid 0 and 3TB Seagate Barracuda
Power Supply: Corsair AX 860i Modular
Case: Corsair 350D
Case Fans: Noctua NF-S12A PWM Exhaust fan and 2 Noctua NF-A14 PWM Intake fans
CPU cooling: Corsair H100i with 2 Noctua NF-F12 PWM fans
OS: Windows 8.1 Pro 64 bit
Every once in a while my computer will crash either if I am browsing the internet or playing a game. When it crashes, it shuts off and then tries to reboot then after 2 seconds it cuts off, then tries again. It goes in an endless cycle until I turn off the psu switch and let it cool off a few minutes and clear cmos. Then I turn it back on and load bios profile and it is good to go.
I thought it was the graphics card but I changed to a new one and then I thought it was the overclock so I ran it at default and these events started to occur again. I cleaned up and rewired the cables and it ran fine, didn't have any crashes so I was thinking maybe there was a short in the wires somewhere.
Next I changed out all the fans and used the resistor to quiet up the fans even on the h100i. I am not using corsair link because it isn't really compatible with windows 8.1 yet. But just now I was in Diablo 3 for about 4 minutes I saw a little bit of smoothness issues about 3 seconds before it crashed again. I took the side panel off and turned off the psu switch and then back on. I was still getting the crash before post. I waited another 2 minutes with the psu switch off and tried it again. I was able to get into bios and reload my profile.
Do I have bad ram, a faulty psu or motherboard?
The bios default runs the ram at 1333mhz and cpu at 3.8 and I was still getting those random crashes. On the overclock profile I have the ram at the correct timings and rated speed.
Case: Corsair 350D
