[Need advice]What CPU should I get?
borisvodofsky
3,606
Fair enough. Thanks for all the help! Going to read around the forum for some info on overclocking in case I need to for anything.
Go buy the stuff right now, almost everyone here has the same intel setup.
We can get you to your overclock target within 2 hours. ;)
borisvodofsky
3,606
Maximus V had 8 phase's and shamino has taken a 3770K past 6.7Ghz. Not all about the phases bro
overclocking is luck, but what i'm trying to iterate is the only feature WORTH comparing between these budget platform motherboards z68/z77 is Phases.
All those other fancy sounding but more/less useless features, like ssd caching, and wifi, that's just marketing fluff. :whiste:
Ventanni
1,432
142
Not to defend AMD, as Intel CPUs are clearly superior (hence why I have one), but I doubt the OP would notice the difference playing TF2 if he were using a Bulldozer or an Ivy Bridge. Not that there wouldn't be a measurable FPS difference, but not one to be noticed by the human eye. TF2 isn't exactly difficult on the hardware requirements.
With that said, the system Don suggested is clearly superior to anything you can buy already premade. The OP will be very happy with its performance, and then some.
borisvodofsky
3,606
With an Intel setup, there will be a significantly higher MINIMUM Frames per second.
The game will feel much smoother, because there will be far less frame dips, when the onscreen action gets extreme.
Given that TF2 if most often played with 32 people during busy hours, an Intel CPU is invaluable. ^_^
Ferzerp
6,438
107
Not noticing a difference in one particular app really isn't much of an excuse for buying an inferior product for similar money.
AtenRa
14,003
3,362
Hey this is my first post and I am looking for some insight into what processor I should get for my new pc I am building. I am on a budget and am trying to keep it around 800$ With this budget I am probably going to stick with AMD considering from what I have seen they are cheaper for what you get. But if there is an Intel out there with better bang for my buck, please share!
I want my pc to be able to run modern games like Guild Wars 2, Crisis 2, Arma 2/3, etc.
I want to choose between one of these 4 processors
AMD FX-4100 CPU (4x 3.60GHz/4MB L2 Cache)
AMD FX-6100 CPU (6x 3.30GHz/6MB L2 Cache)
AMD FX-8120 CPU (8x 3.10GHz/8MB L2 Cache)
AMD FX-8150 CPU (8x 3.60GHz/8MB L2 Cache)
I have been told that the 4100 has multithreading and that is good, but not supported by all games. I was also told that most of the time I won't even use the 8 cores if I get a 8000 series. So would my best choice be a 6100?
Since this is the CPU section, I won't go in depth into my video card choice but I think I am going to get the AMD Radeon HD 7770 - 1GB and my mother board will most likely be the Gigabyte GA-970A-D3 -- AMD 970 with 4 GB [2 GB X2] DDR3-1600 RAM .
Any advice would be greatly appreciated!
Please state what resolution and if you will play BF3 MP. For DX-11 games the HD7770 is too slow for 1080p gaming.
borisvodofsky
3,606
acheee achheeeemm... well you see, an amd processor is too slow to run games at any resolution.
I've read the information inside your blog, and those results are very skewed, further proving that amd can't game worth crap.
The benchmark runs in you sig, seems to be heavily biased information. I can't say this enough.
AMD faildozer is Garbage. :whiste:
AtenRa
14,003
3,362
Consider the following as well,
AMD FX-6200 Zambezi 3.8GHz (4.1GHz Turbo) + ASRock 970 EXTREME3 combo = $229,98
http://www.newegg.com/Product/ComboD...t=Combo.956260
G. Skill 8GB DDR3 1600 - 46.99
http://www.newegg.com/Product/Produc...82E16820231428
ASUS HD7850-DC2-2GD5 Radeon HD 7850 2GB = $259,99
http://www.newegg.com/Product/Produc...82E16814121623
ENERMAX NAXN 82+ ENP650AWT B 650W ATX12V 80 PLUS BRONZE = $89,99
http://www.newegg.com/Product/Produc...&SID=u00000687
CPU + M/B Combo : Nice combination, you can OC that CPU at 4.2GHz with default Vcore and Default CPU Heat-sink. You can even upgrade to 8 core PileDriver CPU in the future.
GPU : HD7850 will allow you to play every game at 1080p with very high Image Quality settings, unlike the 7770.
PSU: More Watts + 80 Bronze, you will have the wattage to upgrade to higher GPU and or CPU in the future.
All that for only $15 more over the previous recommendation. I believe this is a much better and more balanced configuration for a Gaming system while keeping the cost close to the price you are willing to spend. ;)
lehtv
11,897
74
@ ponyxslayer
Get a 7850. I recommend Sapphire, it has an excellent cooler and it's only $240. To afford it, you can back down to an i5-3550 $200 AP and Asrock B75 $72 AP with stock cooling. Overclocking only really matters when you're CPU bottlenecked anyway; 7850 will nearly double your framerates over 7770 with OC.
@ AtenRa
You're seriously suggesting FX-6200 over and i5 just to spend more on an overkill PSU? o_O
AtenRa
14,003
3,362
@lehtv
I believe you missed the HD7850
Edit: The i5-3550 is nice too but i prefer to be able to OC without any limits.
ShintaiDK
20,378
@lehtv
You need to OC..alot to get the same performance. And at what, 3x the power consumption? AMD is just horrible in any way. AMD still sits back in 2006 performance.
AtenRa
14,003
3,362
i5-3550 without OC >>> AMD FX with OC
Since in most of the games he will be GPU limited even the FX6200 will be enough for the HD7850. I dont see why it should not even consider that CPU.
lehtv
11,897
74
Why not make that true in all games? If you can afford an i5, buy it and ensure good performance in all games. FX6100 will definitely bottleneck 7850 2GB in CPU limited games.
i5-3550 is a lot better and doesn't end up costing that much more. You also have to consider upgradeability. i5-3550 can handle the next GPU upgrade, FX-6100 can't. And you have to consider power consumption - like ShintaiDK said, FX6100 would need to be overclocked a lot to even approach the performance of an i5.
Magic Carpet
3,477
234
You will not get higher minimums, if I hand over to you my ancient Geforce 6200.
For the same money: Any FX processor w/ 7850 > any Intel w/ 7770 at 1080p.
Because, well, apparently, the word 'balance' is so hard to grasp, as it seems.
KompuKare
1,236
1,611
Sorry OP, but this is aimed at AtenRa:
seeing that you have actually reviewed and overclocked most of Bulldozers, how would a A6-3670k / A8-3870K compare to the FX-6100/FX-6200 when both are overclocked to achievable speeds?
With the price of Llano mobos and good power gating on both Llano and its mobos, Llano might tempt me. Trinity looks okay too but I expect that the desktop Trinitys will probably be released close to their max clockspeed and leave nothing on the table for tinkering. 2500K/3570K don't appeal to me since at those prices overclocking is no longer fun.
To the OP:
Even with a $800 budget, for any gaming the 7850 is a far better bet than the 7770 even if you reduce your CPU budget. If you looked at something like the i3-2100:
http://www.anandtech.com/bench/Product/288?vs=289
You'll notice that the 2500K appears a lot faster but if you scroll down to games, the difference isn't that much and here the price is something like £90 vs £150. Of course, future games may become more CPU limited but most of the games in Bench are not.
AtenRa
14,003
3,362
I have recommended the FX6200 which is clocked at 3.8GHz base. This CPU even in default will not bottleneck the HD7850. SC2 is an exception to the rule but even a 4GHz Core i will be the bottleneck in that game.
FX6200 will not bottleneck even the HD7970 in most of the games. Games tend to be more GPU bound all the time.
The power consumption in default clocks is not that high. We are talking a few dollars per year maximum. But yes, if you consider this as a high priority then the Core i5 3550 is better.
As i have said before, the Core i5 3550 is a nice CPU. I just prefer a CPU that i can OC with no limits and play with it.
