MY KERNEL IS COMPILING
ok, ./startx works but errors out with "xauth: command not found" and "xinit: command not found" but when i do ./xauth it does find it. 😕
what does "./" do?
what does "./" do?
It runs it from your cwd. with out it it just checks your $PATH's which mostly consist of your bin's and sbin's. If you want to add another directory you should be able to do this
#$PATH = $PATH + /new/dir/here
what does "./" do?
you are soo awsome, words cannot describe it.
alright man. youre gonna scare me away from EDC. hey, wear a geek shirt if you have one, maybe ill hunt you out. looking for people at raves is fun when youre f-ed up 🙂
Ok, you want the mouse to work?
First off, you did enable USB support in the kernel, right?
Right?
Anyway, go into /dev and type MAKEDEV usb and MAKEDEV input
Your mouse should be on /dev/input/mice. Cat it to the display and move your mouse around. If everything is cool, you'll get a bunch of gibberish.
hahahaha. i love it. our 'l33t h4x0r' did not know how to run X or about command paths.
yo kid.. following the step-by-step online does not a hacker make.
No one really cares if you're kernel or whatever is compiling. Just tell us when you're finished and give us a brief paragraph.
yargh, recompiling the kernel with the right options this time!
finally figured out what the help option did in make menuconfig
at least i'm not installing mandrake 😉
can you tell me specifically why you think mandrake is bad?
Oh that's right, you know nothing about linux, carry on.
Reasons why people don't like linux:
#1) Condescending fanboys.
If you were installnig mandrake, you'd be done with this a long time ago.
You see why all my machines run OSes that com from Apple or Microsoft pre-compiled 😉
