- Jan 8, 2011
- 10,731
- 3,440
- 136
The spring clamps that came with the barbs don't fit around the tube. They just don't open far enough even when sprung all the way open. I used zip ties on all fittings besides 3. I will get some on those last ones though. I didn't wrap the zip tie around the barbed section. I wrapped it behind the barbed section and pulled tight to create a tight neck area behind the barbs, so the zip tie is a smaller diameter than the barbed section and is trapped behind the teeth area. I'd like some legit clamps, but if these work then I'm fine with it. I can see the heat eventually softening and causing the tube to work loose, so I fully agree with clamps in light of your concerns.
And yeah, that SLI strap looks like a piece of trash. It works, but its ugly. I'll look at options.
