I'm dropping the photo bomb. This was so much work I can't believe it. Unreal. Anyway, it all looks great and its working. Benches will come later.
My only concern was first time running the pump I didn't see any water being pulled by it at all. The water in the res didn't drop, so I shut it down. It made no noise though at all, so I'm thinking that there was a lot of water in the rad from the first fill and I didn't realize that, and as the water got sucked from the res, it was simultaneously replaced by the rad.
That's my theory anyway and the pump works and is quiet. That first run the pump was only on 2, so I probably just didn't realize it was slowly pulling water. If it runs dry, I would totally hear it whining right? I heard nothing like that so I think I'm ok. Just had noob jitters.
There are a couple barbs that I couldn't get a zip tie around. They are on the bottom and away from all electrical parts, so I'm not worried. The clamps I bought don't even fit on this hose at all, but again, not worried. These barbs hold like a real SOB. I couldn't remove the hose from a barb and I had to do it a few times. All my might and nothing. It didn't budge off that sucker, so I had to cut it off! Those barbs grip like crazy.
I packaged my GPU blowers with screws and heat pads attached, all wrapped up to keep things tidy for later use.
Special thanks to Guskline for personally walking me through many things and suggesting products to purchase. Thanks to all you guys and your good advice and information. This thing is quiet as hell even with fans cranked. All fan controls work and everything else works like it should. Very pleased. GPU idle temps are like 26c and CPU idle 30c or so. I will check under load and do all that and post again with performance information.
EDIT: Ok, did a quick OC and played GTA V. Added 200 to the cores and 300 to the ram for 1380mhz solid no throttling of course. GPU temps didn't break 36c. lol that's funny. I know the loop needs to normalize its temp, but that's still pretty funny. CPU temp 46-53c. Before it was 65c and up during gaming.
