OK I am seriously struggling to figure out how to control these 6 fans. Do I need PWM fans and a PWM fan controller? Or just 3 pin fans and a different kind of fan controller? I read you can damage fans if not controlling them right. The corsair SP120 PWM fans look good to me, but I don't know how to control them. I think corsair commander mini would work, but its not clear to me if it will.
As far as my research found, there is no such thing as a PWM fan controller. Not in the sense that one creates a true PWM signal, the ones that exist simply control PWM fans the same way they handle standard fans, by varying the voltage. You control PWM fans the proper way via the motherboard fan headers. Most recent boards will have a few headers but not enough to control the amount of fans you'll probably be using. To accomplish this you'll need a PWM splitter. Google Swiftech 8 way PWM splitter, there are others as well. Keep in mind the fans you use must properly support signal sharing which it's my understanding those Corsairs do not. Anyway, PWM will allow you to create your own custom fan curve which will vary fan speed based upon CPU load/temp and you can make it as quiet or loud as you wish.
If I'm wrong about those particular Corsair fans hopefully someone will correct me. And yes, I have also heard controlling PWM fans via normal voltage based fan controllers is bad for them.
