Match or ligher?
Match or lighter
  • SMOKER - lighter
  • SMOKER - matches
  • NON SMOKER - lighter
  • NON SMOKER - matches
  • Just show the results.
The reason for the strip is, allegedly, that women were using the matchheads to commit suicide, due to it being poisonous
oh, and strike-anywhere matches are waaaaay more flammable than safety matches. Like, super flammable.
Pretty sure this is why they went to strike on box matches. You could ignite a whole box of strike anywheres by throwing it down. I like strike anywheres. You can light them with a thumbnail.
The one I have is under ten bux on eBay.
Yeah but the cheaper butane models don't get nearly as hot or last as long as a good one does. (I tried several)
This is one of the higher rated models ... cheapest I've ever seen it is $65 + shipping
Blazer Big Shot GT8000 Butane Torch
Read a few reviews don't take my word for it.
It's certainly possible that you found a good one for cheap however propane is still a lot less expensive because the tanks last far longer.
well I use the same tanks for a tabletop butane burner, so it is easy. I use it for burning sugar on creme brule so temp is not a big issue for me.
Ahhh ... it all makes sense now! 😉
When I first got into dabbing I tried using one of these:
While it DID work it took nearly a minute to heat the nail (bowl) sufficiently and in the process of doing so the nozzle got hot enough to make me a bit concerned that it was about to blow my hand off!
