- Feb 27, 2003
- 18,667
- 5,395
- 136
Yeah, I have no problem with it today, because I want to learn it, so as long as I'm not gaining I'm simply doing everything in my Linux VM to learn@Steltek Yeah, but flatpaks suck performance-wise. The last time I had one for a browser, it started as quickly as a native app I had in a VM running off a HDD!
Give it a chanceFor example, instead of going to a website, downloading an install program, waiting for it to download, going through several clicks to install it, then repeat that for however many apps you need to install, best case scenario on Linux is that you type a command like:
sudo apt install vlc
It asks for your password and then just installs it. Also, app updates are all rolled into one system, click on an icon on your taskbar, it lists the updates, click on update all, it asks for your password, done.
You can of course use whatever GUI-based app install system on whatever Linux distro you've picked, for example sometimes I prefer to use the synaptic package manager when I want to search for stuff in the repository.
Of course it's not all roses and sunshine with Linux, there are some things that are a PITA, just bear in mind there are definitely some things on Windows that are a PITA and people have just gotten used to thinking "that's the way things are".
It is just so much easier learning when you can do it in a safe VM environment, where you know you're not going to break anything important and if you get annoyed, you can simply tab back into Windows.
