Throckmorton
- Aug 23, 2007
- 16,829
- 3
- 0
Who here double clutches? I don't because I can't do it quickly, unless I'm slowing down on the highway and have lots of time. I downshift then rev match while releasing the clutch pedal.
People keep associating 'engine braking' with 'aggressive downshifting.' This is not accurate.
I use engine braking like crazy, and I never coast in neutral unless I'm deciding on which gear I want to use (like when there's sudden traffic or something, and I stop in the middle of an upshift).
I do not downshift through the gears when slowing down. I leave it in the higher gear, and shift into whatever gear is proper when I then need to accelerate.
I'm not even sure how people do this. Unless you want it to be jerky and akward, you're going to be manipulating the throttle, which means you're using more gas. In addition to the time spent in neutral during shifting, there's also the effect of more throttle on your deceleration. It's just a pointless exercise.
edit: also it sounds like kiatech drives exactly like me. I generally use 3rd and 4th to limit speed in 30-35 and 45-50mph areas, respectively. If I get into the RPM range where I feel significant braking when I let off the gas, I'm probably going too fast.
And I do ride third like crazy. Unless I'm doing a really slow/sharp right-angle turn (can't 'apex it' very well), I don't shift into second.
Confirmed this with solid proof for ATG long ago with a datalog posted showing injector duty cycle going to zero and AFR pegging lean when TPS went zero and RPM was above idle target.
But we still have this argument at least twice a month.![]()
You're saying you granny shift and don't double-clutch like you should?I do not double clutch because someone invented synchro-mesh making double-clutching absolutely pointless, Mr. Diesel.
