Discussion Leading Edge Foundry Node advances (TSMC, Samsung Foundry, Intel) - [2020 - 2025]
Page 104 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
DisEnchantment
1,779
6,798
TSMC's N7 EUV is now in its second year of production and N5 is contributing to revenue for TSMC this quarter. N3 is scheduled for 2022 and I believe they have a good chance to reach that target.
N7 performance is more or less understood.
This year and next year TSMC is mainly increasing capacity to meet demands.
For Samsung the nodes are basically the same from 7LPP to 4 LPE, they just add incremental scaling boosters while the bulk of the tech is the same.
Samsung is already shipping 7LPP and will ship 6LPP in H2. Hopefully they fix any issues if at all.
They have two more intermediate nodes in between before going to 3GAE, most likely 5LPE will ship next year but for 4LPE it will probably be back to back with 3GAA since 3GAA is a parallel development with 7LPP enhancements.
Samsung's 3GAA will go for HVM in 2022 most likely, similar timeframe to TSMC's N3.
There are major differences in how the transistor will be fabricated due to the GAA but density for sure Samsung will be behind N3.
But there might be advantages for Samsung with regards to power and performance, so it may be better suited for some applications.
But for now we don't know how much of this is true and we can only rely on the marketing material.
This year there should be a lot more available wafers due to lack of demand from Smartphone vendors and increased capacity from TSMC and Samsung.
Lots of SoCs which dont need to be top end will be fabbed with N7 or 7LPP/6LPP instead of N5, so there will be lots of wafers around.
Most of the current 7nm designs are far from the advertized density from TSMC and Samsung. There is still potential for density increase compared to currently shipping products.
N5 is going to be the leading foundry node for the next couple of years.
For a lot of fabless companies out there, the processes and capacity available are quite good.
FEEL FREE TO CREATE A NEW THREAD FOR 2025+ OUTLOOK, I WILL LINK IT HERE
19,219
When it comes to totally screwing the company, Kraznich & Bob Swan hold the crown! World's top two visionaries!
I think Swan can be excused for being put in the wrong position coz he was just a finance guy but Krzanich was actually a fab management guy and he destroyed Intel's fab dominance in his tenure. I mean, he gets the award for "Best way to F up at your job despite having the core competency to excel at it!".
FlameTail
4,384
2,762
Now we to find the guy responsible for crashing Samsung'a fab in the past few years.
They fumbled 7nm, 5nm, 4nm and now seemingly 3nm as well.
Reactions: SiliconFly
FlameTail
4,384
2,762
[Exclusive] Samsung has decided to change the name of the '2nd generation 3nm' process to '2-nanometer.' In other words, the plan is to refer to the 2nd generation 3nm process, which will be mass-produced this year, as '2-nanometer' going forward.
According to a source quoted by ZDNet Korea, "We were informed by Samsung Electronics to change the 2nd generation 3-nanometer to 2-nanometer," and added, "Last year, we contracted with Samsung Electronics Foundry for the 2nd generation 3-nanometer, but recently we re-wrote the contract under the name of 2-nanometer."
It is practically understood that Samsung Electronics recently secured orders for AI accelerator chips based on the 2-nanometer process from the Japanese AI startup PFN (Preferred Networks), which are essentially identified as utilizing the 2nd generation 3-nanometer process. These chips are scheduled for mass production in 2025.
Node renaming shenanigans again....
But there is a difference.
When Intel renamed their 10nm to Intel 7, it was kinda justified, because Intel 10nm actually had slightly better density than TSMC 7nm.
But this move by Samsung is not just justifiable. Their 3nm GAA already has worse density than TSMC 3nm FinFET. Renaming their 3nm to 2nm means the gap is going to be even wider when comparing TSMC 2nm and Samsung 2nm.
19,219
Reactions: Elfear
DavidC1
2,192
3,343
That's why they also lost previous generation comparisons pretty badly because "shrinks" for Samsung were often just plusses.
The old Intel joke of 14nm = 14nm, 14nm+ = 13nm 14nm++ = 12nm applies here.
Hitman928
6,755
12,503
Lol. A few months back I did mention MTL may have a slight performance regression. But I got battered for saying that. :)
I am skeptical of his testing. Another reviewer found no IPC difference between MTL and RPL P-cores with SPECint. I believe the other reviewer used laptops that both had the same type of memory as well, unlike this testing. Both use fast enough memory that it shouldn't effect the score much, but enough to get a 5% shift? Maybe.
Edit: This is the same reviewer that listed LP P-cores in their testing (which doesn't exist) and showed an IPC regression in the E-cores as well whereas Intel said they improved E-core IPC. Now, I don't necessarily take Intel at their word, but the other reviewer I mentioned did show an IPC increase in their testing of the E-cores, right in line with Intel's IPC claims. All of this leads me to believe this was simply faulty testing and there is no IPC regression in the P-cores and an IPC increase in the E-cores, which is basically what Intel said themselves.
Edit2: He also has entries like this in his table of SPECint scores:
How do you calculate IPC from a score if you don't know what the actual clock rate was when running the benchmark? Did he actually track the average clock speed or just use the mid point of his range (which would most likely be inaccurate for IPC calculation)? Too many questions and things that don't add up for me to trust his testing.
FlameTail
4,384
2,762
All these "nm" don't make sense anymore. It's been more than 20 years since node names actually represented transistor metrics. In Intel 20A, TSMC N2 & Samsung 2nm, the actual transistor is actually around 10X bigger (or more) I think. All these 20A, N2, SF2 are pure marketing tricks. I don't think we should take them seriously anymore going forward.
I think we all know that already.
What we want is for the foundries to align their naming schemes.
Reactions: Tlh97 and Elfear
moinmoin
5,248
8,463
It seems Samsung doesn't want to admit its own inferiority though. So they keep crying for attention.
The bad thing about it is that if Samsung at some point actually has something competitive with leading edge too many potential customers may not care anymore.
FlameTail
4,384
2,762
They will have lost reputation not only among semiconductor companies, but even the general tech community.
For instance, if you check out the Android tech communities in X or Reddit, you can see that the majority of people have less respect for Samsung Foundry, as they are aware of Samsung nodes' inferiority.
Hitman928
6,755
12,503
[Rumor] Meta may be switching from TSMC to Samsung to manufacture their custom chip designs:
19,219
Where are these chip designers coming from? Isn't this supposed to be a black art of sorts or did someone opensource a recent chip design that everyone and their granny is coming out with their variation?
