bryanW1995
i didnt know people still did this. i remember reading years ago that lapping usually doesnt improve temps
It usually helps. I've done it a few times to good effect, though never with 3000 grit!!
ON the "ineffectiveness" issue -- I'll answer with another question: "What's the purpose if releasing a "K" version of a CPU, if you can't change the multiplier much beyond the default "turbo" level?" That is, some IB purchasers feel limited to that degree.
Then their feelings are unwarranted and un-educated ..
Bumping the multi +10 with an IB, and using a $30 air cooler to keep temps well within a decent range, is hardly being limited..
Will these various aftermarket TIM option last the lifetime of the chip without drying out/cracking though? Intel don't have the luxury of using some exotic TIM that will last 3 or 4 years before it needs cleaning off (let alone the 1-2 years which is the max I would use TIM for before removing/replacing it) and reapplying, they need whatever they use to last 6 or 7 years and I am not aware of an aftermarket TIM that I would be happy relying on this for, let alone an aftermarket TIM company that advertises it's TIM will last this long.
While overclocks like this work, I'm interested in the longevity of these chips running such high temps. I always try to keep my chips below 60C but I suspect that I'm too conservative.
You are way too conservative. I've run cpus for well over a decade, with temps into the low '90's at times (though usually high '70's is more typical) 24/7 with seti@home with optimized apps, and I've never fried a cpu. Temps are somewhat important to chip longevity, but voltage has a much greater impact. I've never use h20/etc, and I've always stayed relatively close to recommended levels on vcore, but I never worry about temps until they get into the '90's.
For the name of science!Once you're going to the trouble of delidding, why not skip the lid entirely and mount the cooler right on the die?
A bit riskier, but eliminates the problem of TIM and balancing the spreader etc. entirely.
You are probably right that it might be less work and produce better results; however, I'm glad we are just playing around with a few variables. This helps us understand the TIM vs solder debacle a lot more than just removing the IHS entirely.
You are so anal in a good way 🙂
Interesting so far....Waiting for the next round of updates!
Easy... Intel is not going to change their assembly processes to appease a small handful of over clockers, so you don't have to worry about it. You're high and think way too highly of yourself if you think a few forum members stumbled across a discovery that dozens or maybe hundreds of Intel engineers didn't already know and now they're going to modify their assembly lines. So you can comfortably buy IB knowing it's going to have TIM.
And I've done enough searches to know its a small handful of people complaining about it over and over. Intel isn't going to change anything. Why would they change their entire assembly line? Are you going to go AMD if not?
And the one thing that would have cost them more money in the long run is in-field fails that must be covered by warranty. No one wants that, the risk of it is one of the huge incentives that process engineers have in scaling existing solutions versus implementing brand new solutions like HKMG or 3D xtors.
We had a huge in-field fail issue at TI when we were the first to introduce a lower-k dielectric material into the BEOL (we used HSQ vs everyone else using SiO2 at the time) and we didn't enough testing to capture the reality of stress-induced cracking that would happen in the dielectric from thermal cycling. Thereafter we were keen to never repeat that mistake, it was extremely costly (hundreds of millions of dollars in warranty charges).
With Intel changing so much of the xtor structure at 22nm you can bet they did extensive/exhaustive internal testing to ensure the risks were fully identified and mitigated. It makes engineering and financial sense to conclude the shift in soldering the IHS to the CPU at 32nm to now just putting a nice malleable TIM at that interface at 22nm (at great expense in terms of lost revenue in all product segments) must have been done for stress and thermal-cycling reasons.
While you are correct that there is a lot more to it. I disagree in that for optimal science we need to go step by step.It really doesn't. New manufacturing process, smaller surface area... There's more to it then just solder vs TIM.
IDC, are you planning to test anything other than NT-H1 under the hood?
I would be very curious to see how those liquid metal TIMs function, preferably both under IHS and also between IHS and HSF. Seems like those would be the best thing short of solder like Intel used previously.
And that's another topic - would it be possible to use solder somehow under there?
I might try some indigo extreme, but that is pretty much an irreversible situation given that the bare CPU die itself is involved.
When I used indigo extreme before on my 2600k I had to re-lap both the IHS and my NH-D14 in order to fully remove it all. Removing it from the CPU chip would most likely result in catastrophic failure, so if I put it on there its going to be the very last test I do because it will be permanent.
Well, if I beat this dead horse some more, we can make dog food and meatloaf. Or meatloaf from the dogfood.
Speaking of pet-food, BallaTheFeared wants some red meat. There's enough out there -- links I and others posted -- You can pretty much assure yourself that the time spent tediously removing the cap and applying a good remedy is going to lower your temps for an over-clock. I want to see IDontcare's results, but it won't be a decision-factor at this point. If I buy the i7-3770K, the de-lidding will be a "done deal."
