AtenRa
But surely you want CPI to go down, not up? (Unless you get a massive clock speed boost.)
Heh, you are correct i was thinking in IPC terms, CPI will go down.
It seems to me we will get more confusion like that, ill stick to IPC.
I'll take 15% faster CPU and 30% faster GPU. For me the GPU is more important but it must be horribly bandwidth limited still on DDR3.
AMD's current marketing says that Steamroller is supposed to have 30% higher IPC than Piledriver. Obviously, this can't be taken at face value, but Steamroller is a major revision (not just a minor tweak like Bulldozer->Piledriver) and there is enough low-hanging fruit in the new architecture that 15%-20% increased IPC in most applications seems plausible.
No, generally the 8100 is about 10-20% faster in fully MT situations.
I have benchmarks that say the contrary.
Sorry, I misread your post. I thought the comparison was 6300 and 8150 (I cannot find 8100 on newegg).
Key word is fully Multithreaded.
And yes there are exceptions but generally the 8150 is about 10-20% faster than the 6300.
BTW, where is Seronx and his claims of 2m4c SR = 4m8c piledriver?
DDR4 should doHopefully that's the case and in the future AMD would be able to tap in more shaders into the iGP without coming into serious bottlenecks from RAM BW.
A 15-20% for the CPU and a 25-30% for the GPU seems feasible.
AMD claims 30% over Bulldozer, which implies 20% over Piledriver.
I suspect we'll see 600 TFLOPS on the top end mobile part (eq. 7730) and 900 on the desktop (eq. 7750). 8 CUs (512 shader cores) @ 550 MHz for mobile and 850 MHz for desktop doesn't sound too far fetched.
Top end Kaveri needs to be hitting 1 TFLOP of GFLOP performance,
It has been detailed at last year's HC and AT wrote about it in their SR article 😉.Any word on the cache system?
2T eDRAM or 6T SRAM, choose. 6T SRAM is the safest bet though. Other than the size and pipe width increases it should be exactly the same as Bulldozer.Any word on the cache system?
TSMC is fabbing Kaveri, just so you guys know.Kaveri might be affected by Globalfoundries 28nm High performance process which seems to be having serious issues. the only 28nm process ramping at GF currently is 28nm SLP suitable for ARM chips.
The GlobalFoundries and AMD thing has become increasingly hostile. While the TSMC and AMD thing is becoming increasingly friendlier.That's not what AMD said.
