PlatinumRice
no, they had to GET the uranium to enrich first...
they had everything else, so they weren't very far away from a working prototype.
they had the tech to enrich uranium.
basically, they just had to put it in a bomb after that.
And without an engine and no rubber to make tires and no steel to make an engine and no heat to make steel. The OP is so far off base on what it takes to build an A-bomb it's just stupid.that's like a Ferrari without the engine...
Quit making shit up. Japan did not have the industrial capacity to produce sufficient enriched uranium to build an atomic bomb.
Again, quit making shit up.like i said, they had everything else, they just needed to get a sufficient amount of uranium to make one.
if they could have built 10 or so bombs, they would have done significant damage to the american fleet using kamikaze pilots.
http://www.youtube.com/watch?v=F1PvA6LOlhM&t=24m24s
if germany didn't screw up, they would have gotten enough for 2 bombs.
what else did they need?
like they just need to enrich it and put it in a bomb.
http://en.wikipedia.org/wiki/Enriched_uranium#Thermal_diffusion
www.youtube.com/watch?v=F1PvA6LOlhM&t=24m50s
it was working!!!!!! they just needed to put it in a bomb!!!!
enriching uranium is the hardest part, the rest is child's play.
Again ignorance is your only shield. While the US developed gas centrifuge enrichment during WWII it abandoned the program in favor of gaseous diffusion as centrifuge technology was not sufficiently advanced at the time. Again the idea of the thing does not equal the thing. If you have any inclination toward learning actual history instead of just making shit up I suggest you stop posting and go read the book I linked above.![]()
http://en.wikipedia.org/wiki/Japanese_nuclear_weapon_program
F-Go Project
In 1943 a different Japanese Naval command began a nuclear research program, the F-Go Project, under Bunsaku Arakatsu at the Imperial University, Kyoto. Arakatsu had spent some years studying abroad including at the Cavendish Laboratory at Cambridge under Ernest Rutherford and at Berlin University under Einstein. Next to Nishina, Arakatsu was the most notable nuclear physicist in Japan.[14] His team included Hideki Yukawa, who would become in 1949 the first Japanese physicist to receive a Nobel Prize.
Early on in the war Commander Kitagawa, head of the Navy Research Institute's Chemical Section, had requested Arakatsu to carry out work on the separation of Uranium-235. The work went slowly, but shortly before the end of the war he had designed an ultracentrifuge (to spin at 60,000 rpm) which he was hopeful would achieve the required results. Only the design of the machinery was completed before the Japanese surrender.[11][15]
Shortly after the surrender of Japan, the Manhattan Project's Atomic Bomb Mission, which had deployed to Japan in September, reported that the F-Go Project had obtained 20 grams a month of heavy water from electrolytic ammonia plants in Korea and Kyushu. In fact, the industrialist Jun Noguchi had launched a heavy water production program some years previously. In 1926 Noguchi founded the Korean Hydro Electric Company at Konan (now known as Hungnam) in north-eastern Korea: this became the site of an industrial complex producing ammonia for fertilizer production. However, despite the availability of a heavy-water production facility whose output could potentially have rivalled that of Norsk Hydro at Vemork in Norway, it appears that the Japanese did not carry out neutron-multiplication studies using heavy water as a moderator at Kyoto.[11]
Historian Rainer Karlsch has alleged that shortly before the end of the war US intelligence acquired information to the effect that Japanese scientists had planned to conduct a test of a nuclear weapon near Hungnam on 12 August 1945. However, this could not be verified as the Red Army occupied Konan a few days later, before US occupation authorities could investigate fully.[14]
They just had the design of the centrifuge just before they were nuked...ergo no enriched uranium.
And the fucker in your picture is about to be put in his place.
centrifuge = one enrichment method
thermal diffusion = another enrichment method
after enriching enough uranium, you just have to design a bomb for it.
