- Apr 10, 2001
- 48,775
- 3
- 81
Originally posted by: Nebor
Very good quality! DD 5.1 and all. :thumbsup:
If you have s/pdif, make sure to select it under audio device...gives it a nice boost
If you have s/pdif, make sure to select it under audio device...gives it a nice boost![]()
Blame Devioustrap![]()
Sure go ahead.
Each shared hosting account is limited to allow 20mbps outgoing , so as to not interfere with the service other customers are getting. Right now, a quick check at outgoing on your account shows 17.53 MBits - Meaning in total 2.19 MB/s is being download (most probably all of it is that one file).
I've found some software decoders that are superior to my Audigy 2's rather poor S/pdif decoding.
Sure go ahead.
I KID!![]()
Sure go ahead.
I KID!![]()
I don't- You can bump that up to 18.12mbps outgoing
I meant if you have passthrough.
BTW, the upcoming clip has DTS:Q
Damn. The wmv one actually loked fantastic despite the small size. It took care of the deinterlacing nicely too. That said, there is no audio and it plays at like 2fps so I won't post it![]()
How do I transcode a .ts file to WM9 with Windows Media Encoder?
I know I can do a SVCD file with WinDVD installed.. But I also have PowerDVD installed now. I know that wouldnt work properly with WME9..
.ts into moviemaker.
basiccally create a custom profile using windows encoder and save it in the moviemaker profile directory..it takes FOREVER to encode, but it looks real nice.....
The file C:\Documents and Settings\Ryan\Desktop\2005MastersGolfTournament.TigerWoods.CBS1080i.DD51.ts is not a supported file type, and it cannot be imported into Windows Movie Maker.
Who's up for some 4GB TS episodes of seinfeld?![]()
Originally posted by: SarcasticDwarf
Dayum, My 3200+ with 1gb of ram couldn't run that without artifacts.
Originally posted by: SomeDude22
it wont open in WMV or RP
DUDE......YOU OWE ME![]()
I have absolutely no way of hosting a 4 GB file. I don't think many people on ATOT do.
Can you break it up into parts. Then you can e-mail the parts to us.
