Is $3200 - $300 Mail In Rebate Good for a 42" Plasma TV?
MrScott81
1,891
Your straight tv picture will look good if you have satellite tv or some sort of digital cable and you plug it in through the svideo connector to your tv in...regular cable however you might be a little disapointed...
tedinde1
365
Costco's Unconditional Double Guarantee
On merchandise: We guarantee your satisfaction on every product we sell by offering a full refund.
I shop at costco once a week. Their guarantee is simple. I have never seen a time period though.
rockyct
6,656
32
Gateway will start selling a 42" plasma TV for under $3000. You can read about it here. They are actually LG Philips TVs also.
GregFish
63
I saw the Gateway Plasma at a Gateway Country Store tonight and it looks awesome! The plasma is supposively from Phillips. I don't think there is a plasma that has better value for the money right now and I hope this one helps drive the other plasmas down. They have dropped a lot this year already. I have seen the Sampo before too and in my opinion the Gateway looks far better.
patrickj
2,252
I think I'd just stay away for now...prices will continue to fall, and after Christmas sales are going to be fantastic this year.
DUKAT1
1,543
My understanding is that this is not a true hdtv, but is in essence a "enhanced definition" television. While it will accept 1080i or 720p signals, it converts them to the native resolution of the screen, which is 480p. Don't get me wrong, a good 480p can really look great. It just is not really high definition.
See the specs here
rootaxs
2,487
Just a note about Sampo.
Back in the Philippines most computer monitors you find in the market are made by Taiwanese companies - Sampo being one of them. I had the pleasure of getting a couple of these back then and to this day they work without a hitch (that's 5 years now).
I actually see a lot more Mag and Viewsonic monitors being RMA'd than Sampo. And to think they both sell in similar numbers.
lupohki
1,925
Originally posted by: cmbehan
Originally posted by: Caveman
I'm confused... How does having great resolution somhow change the quality of the picture coming in ona standard TV signal?
It makes the imperfections that you get in standard def analog signals more apparent, and slightly irritating. I have a 65" Rear Projection HDTV, and for movies and HDTV, it's wonderful, but for standard TV, I'd rather watch on my old JVC 32" standard tube. The Plasma's emphsize these imperfection even more.
It's even worse when it's a 1600x1200 LCD (Dell 2000FP).
nippyjun
8,447
Don't buy something this expensive on ebay unless you can buy it from a local seller so you can inspect it. Even then, you're taking too big a risk.
Originally posted by: lwlee
targg,
Good comprehensive review.
I've been eyeing the Panasonic 42" on ebay for $3600. How's the scaler on these models? Better than Sampo?
Given the quality on the Sampo, how is it for viewing regular broadcast and cable tv? Is it fairly close to a good flat screen tv like the Wega or Tau? Or will I regret buying it and replacing my Tau?
At Best Buy, I haven't noticed the untrue blacks that you have mentioned. The plasmas that I have seen, I think it was the Philips 42", seem to have an outstanding picture with great clarity and color.
lwlee
Originally posted by: targg
Here's my 2c, and I actually own one of these so its not random opinion or heresy. Sampo is not a sony "sister company". They havent got a thing to do with each other. These panels are built on Fuji flat panels although fuji doesnt market their own sets directly. Sampo is a big company that makes products on a perceived value/quality scale as say a samsung. Not as good as a sony/toshiba sort of level but certainly not "boo-bobs tv's and video emporium" level.
<more good stuff...>
targg
85
Hey no problem, I spend stupid money on stuff so you guys dont have to ;)
The plasma's will generally look great with progressive scan dvd players on them, mine is a knockout even for a cheapie. Its really designed to take a progressive scan input from the rgb or component input, with the composite/s-video being poor step-children. Thats why the vb50/n5 trick sidesteps the shortcomings of the cheaper plasmas by prettying up the picture and shooting it through the rgb.
As far as the panasonic goes, they tend to be a step above, but watch out for older plasmas, they tend to run hotter, have lesser lifespans, and many of them have fans in them. Yes...fans...loud as a pc. If you like turning up the volume an extra notch to drown out the humming, its not a problem. My guess is that panasonic at that price point is a first or second generation unit. May be good, may not be.
Program source wise, here's the deal. Good analog cable through a vb50 should look ok on a plasma, but I think if you compared them you'd agree that even a basic tube-based tv will look as good or better, and a rear projection hdtv will look better than that. Good digital cable or satellite on a high resolution channel will look good when piped through a vb50. Note I said "high resolution channel". Most digital cable and satellite providers give best bandwidth to pay per view channels, then to the hbo's, but the local broadcast channels get the short end of the stick. These guys have to supply a lot of local channels so they cant give full bandwidth to each and every one. Hence your "common" channels are going to have short shrift compared to the ones people will pay extra money for.
The plasma is really a 1 trick show. Flat, looks good with high def sources, decent with others. The LCD's similarly offer simplicity and cooler operation, but check them out with a high motion program like a football game, they're often too slow in transition and you'll get shimmering around the motion. RPTV's are big but beautiful and inexpensive by comparison. Of course money solves all problems, as i'm sure folks with a more expensive hdtv will speak well of them, whether plasma, lcd or rptv.
And yeah, when you're input source is less than the unit traditionally displays, AND its stretching it, AND its a bigger overall picture than normal, AND your doubler/scaler/converter has to interpolate the picture by filling it out to a native resolution...the quality has to suffer compared to a 30" direct view set.
If space is a problem, but you can swing a projector, look at some of the 1500-1700 DLP projectors. Many of them only look good with the 15 pin rgb monitor input, buts thats where our $99 vb50 swings into action.
Bottom line: unless you have bucks for this and/or NEED the flat tv dealio, its a huge waste of money.
Wooster
1,463
It's made by "SAMPO" which I had never heard of prior to today but was told that it is a Sony sister company...
That's not correct. I brought a Sampo walkman back in 1980's and was told they are Sharp just like National is part of Panasonic. After doing some research, that's not complete true but close enough.
http://www.sampoamericas.com/about.php
vfdfs2
142
Prove that they are, then.
If you cant prove it, then theres no point to your quoting.
Originally posted by: Dznuts007
Originally posted by: vfdfs2
Who told you Sampo was Son'y sisters company?
Sampo is a Taiwanese company.
I doubt that it has anything to do with Sony.
Just because Sony is a Japanese company and Sampo is a Taiwanese company doesn't mean that they can't be sister companies. When I went to elementary school, it was a predominantly white elementary school...but 2 cities away there was a predominantly hispanic elementary school, but we were sister schools... :p[/quote]
antilamr
403
Hey targg, how about a little pm action for some more info on the vb50/n5! How does it look when converting to a regular tube hdtv?
antilamr
403
antilamr
403
GermyBoy
Banned
Jun 5, 2001
3,524
Definately not. You can get a better quality HDTV for less money, and it won't irritate you as much. Plasma tvs are definately not worth their money. Go into your Best Buy and shake one and you'll know what I mean.
Peace,
GermyBoy
iamwiz82
30,772
13
Peace,
GermyBoy
but in areas where space is a value commodity, these are a godsend. I'm thinking of one for my living room abve the fireplace, since its a relatively small room and then i could dump the ugle entertainment center.
targg
85
I havent tried the vb50 with a regular tube/projection hdtv but if you have one and arent satisfied with the pic quality when using rf/composite/s-video inputs I'd definitely try one - providing the tv has a 15 pin rgb monitor input for the vb50. Worst case its no better and you take it back. Theres supposed to be a nextvision N6 coming out that does component input as well and processes that, but I havent seen it yet.
On using a plasma above a fireplace - in short, you cant. Between heat and soot, the tv would be shot within a year. Perhaps less. If there is NO heat updraft from the front of the fireplace, the wall behind the unit can sustain an 80-100lb tv anchor brace set, the wall itself doesnt warm up at all when a fire is running, there is NO soot updraft, and you have a shelf below the tv to divert any heat/soot when the fireplace doors are open its feasible but highly not recommended. These things are HOT. It heats my 20x25 room with vaulted ceilings several degrees per hour. In the summer I have to put a small fan on the shelf with it to cool it down a little. I had to move the satellite receiver and tivo off the shelf above it as the heat updraft from the plasma was burning them up. In that application I'd use a DLP projector and mount a pull down screen above the fireplace. Half the price.
I also wouldnt recommend going to the store and "shaking one" unless you bring your checkbook. The front face of a plasma is a sheet of glass, and not too thick at that. You shake it, you might break it, and you have a really big paperweight. You cant even mount a plasma the way they show in the philips ad on the ceiling, the weight of the glass will break it. In fact, they have to be shipped standing up and should never be tipped from a vertical position. If you have one shipped, make sure it has a shock guard and tip guard on the box or make sure you see the glass before you sign off on it.
I was looking at one unit and had the shipper tell me on the phone that I wasnt allowed to look at it before signing, so I called the company and told them to tell the shipper to send it back as I'm not taking a $3500 piece of glass from a shipper sight unseen. The next company I ended up buying from was a little more reasonable.
One more thing I forgot. For some reason the makers of these decided to use obscure remote control codes. I havent seen any of the cheap ones work with a non-learning universal remote. I have a tivo and an x-10 universal remote and neither can control either plasma i've tried them with. I can use the vb50's remote to control the power/volume on the plasma by setting the plasma to PC monitor mode and enabling DPMS. When I shut the vb50 off the screen detects signal loss and goes into standby; when I turn it back on the screen comes back; and I routed sound through the vb50 so it can do volume control. I was about to have to buy a tool belt for all the remotes I needed...
Overzeetop
88
I have a Viewsonic VB50 on the 15" DELL FP151 I got two weeks ago. It is fine for it's purpose, though my analog cable is fairly low-quality stuff. I haven't fed it the DVD signal yet (through a modulator), so I can't say anything about the upconversion, except that it's fine for regular TV viewing. FWIW, buy.com has the VB50 for $99.72 with free shipping. I used the $10 off 99 visa promo to get it for <$90 shipped.
Linky
iamwiz82
30,772
13
the wall in front of the fire place does not heat up. The fireplace actually deflects off to the back, not straight up.
Analog
12,755
Peace,
GermyBoy
I would agree, but $3K is still pretty steep!
