Intel processors crashing Unreal engine games (and others)
Page 28 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Saylick
4,036
9,456
KompuKare
1,228
1,597
"may reduce processor reliability."
Is that temporary here-and-now reliability, or long term we-have-degraded-your-CPU reliability?
And, are they actually going to release and official statement including RMA and warranty info?
Reactions: lightmanek
Saylick
4,036
9,456
Just sad. I don’t see how this isn’t anyone but Intel’s fault. If the CPU vendor can’t identify the root cause with all the resources at their disposal, how can we blame mobo vendors or reviewers who have only a fraction of those same resources?
My cynicism tells me Intel likely will just sweep this under the rug since they’ve moved onto MTL and soon enough LNL and ARL.
Thunder 57
4,027
6,741
LoL at Tom's for simping for Intel.
eTVB technology is an exclusive feature for Intel's Raptor Lake chips, specifically the Core i9 SKUs, so the ongoing instability issues don't affect the rest of Intel's processor population. eTVB is a great asset for Core i9 processors since it gives them a burst of performance in games and applications that prize high clock speeds.
Yup, let's not focus on them crashing and still not identifying a root cause. eTVB is awesome, trust us, just buy it. /s
I have a feeling Intel knows the root cause. They are just trying to figure out a way of saying they overclocked their chips too far without actually saying that.
branch_suggestion
826
1,805
When you have a good part and a good node you can settle for a very comfy stock part and have everything you need.
Intel meanwhile has leaned desperately hard into the 'gamer stable' crowd which is just a paradise of grifters, not to mention the lack of oversight on OEM BIOS settings.
Why? Because the thing at reasonable clocks has no competitive edge at all.
19,131
Intel just refuses to learn from their mistakes. They ignore that Broadwell was still decent for gaming even in 2020. They ignored the performance advantage of 5800X3D. Heck, when AMD demoed their V-cache prototype, Intel should've embarked on a competing solution that very same day. Then they would've had something to show maybe three years later. But no. These dumb idiots running the show at Intel (Pat's underlings) think that brute force frequency ramping is the solution to everything. It's like they don't understand anything about the importance of latency masking. And the engineers there must be real chickens**ts for not speaking up against stupid marketing decisions.
DAPUNISHER
32,012
32,465
TLDW = Why did you buy Raptor Lake high end for gaming again? LMAO
Note: I don't think Steve knew about the TVB bug at time of filming, which may contribute to the issues even if not the primary cause. Consequently, his conclusion to use the XTREME!!1! profile may be inaccurate due to that lack of updated info?
Regardless, if you bought the K SKU and did not plan to manually overclock or tweak it (as numerous responses on r/Intel, reddit, and youtube have asserted) you did not get the performance you paid for. I'd suggest the performance profile as the power savings outweigh the performance regression IMO.
KompuKare
1,228
1,597
Demoed? The 3D vials were there in Zen3 for ages before AMD said anything and I cannot see how a corporation the size of Intel had not taken an Xray images of Zen3 by then.
As for Broadwell - well that was one of the most interesting Intel CPUs in years but was so largely ignored.
coercitiv
7,355
17,424
Stay tuned for Season 2!
TL;DR - New Default Settings for Core i5/i7 SKUs, eTVB microcode update, but no final solution to instability issues.
KompuKare
1,228
1,597
i5 and i7? So much for "it only affects some i9 SKUs" then!
19,131
Will check again after 31st May for a newer BIOS version and see if ASROCK has "fixed" the IccMax value.
Updated to the 11th June BIOS. IccMax is still Unlimited at default settings. However, Turbo Boost Power Max is now 241W by default, instead of 125W.
I'm guessing the BIOS may be applying safe default settings for only 13th/14th gen K CPUs.
ferson
36
What are the chances that setting to XMP in the BIOS can play a big part on this instability? Afterall, XMP is considered a form of overclocking as in it runs the memory at speeds faster than what the CPU officially supports, and I wouldn't be surpised if there are people who build their own systems and don't pay attention to what the memory controller on the CPU actually supports and just buy the fastest memory they can afford and that motherboard they buy supports and then set to XMP in the BIOS to get their memory to run at it's advertised speed, even if they don't have the intention of overclocking. Also I used to own a motherboard that if I enabled XMP, it would overclock the all-core turbo speed to it's single-core turbo speed for all core loads.
Yeah a friend of mine did that. He ended up having cpu temperature issues.
Bencher
54
10
51
And yes, we all know the first thing a gamer does is power limit their CPU, right? /s
No, because they don't care about efficiency. If they did, why wouldn't they?
But that's besides the point honestly. The point is, if 14900k is "worse than Bulldozer" what are your feelings about the 7950x when it consumes more power while being slower?
Thibsie
1,127
1,334
That's exactly the point.
It doesn't mean this data isn't interesting and , honestly, if I was an Intel guy looking (or already owning) a 14900k CPU, I'd be VERY interested in this.
But very little number of people will do any of this. Note that this also applies to Eco mode on Ryzen.
I'm happy it is there but it should never be used to compare CPUs general performance.
Note that you didn't (maybe neither TPU) mention if this was with latest bios, security patches et all (for Ryzen too of course).
DAPUNISHER
32,012
32,465
You are off to a bad start here. I deleted your other off topic posts.
We require you stay on topic. Your posts have nothing to do with 13th and 14th gen CPUs crashing in games. An issue Intel is aware of and efforting a solution to.
Also, please read and follow all of the forum guidelines and CPU forum rules.
Mod DAPUNISHER
Reactions: Tlh97 and Joe NYC
vanplayer
66
113
66
Literally, problem is still there.
The Windows event viewer is full of the above “NVIDIA LocalSystem Container” crash logs. This has been widely confirmed to be an Intel CPU-related issue wherein the processor becomes unstable due to whatever reason. As already mentioned, this unit is the second RMA replacement and has been running using the “Intel Default” power profile and the eTVB firmware fix.
I assume future UE5 game would have same fate on Raptor CPU.
