Page 937 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
935
848
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Khato
1,344
427
Yes, but the Intel ARC 390 is not 60W full system but 70W CPU sustained, actualy
70W sustained PL1, 85W PL2 and 212W PL4, Computerbase also did a test, so there s a long shot from 60W full system to say 65W sustained CPU power.
You want me to set my computer to a 1000W TDP and then claim its efficiency is absolutely horrible because it's not running any faster at 1000W than it is at 250W?
Again, the 60W full system power was measured by PCWorld, around 2:45 in their video coverage -
Reactions: ToTTenTranz
Abwx
11,991
4,946
You cant always use power at the main because there s sometime instances where the CPU drain power from both the AC adaptator and the battery, Computerbase did a review with the CPU at 70-65W, check the numbers, if they are the same as PCW it means that the latter is not accurate, beside Computerbase test is done at stock and they have the power settings displayed in HVInfo.
poke01
4,704
6,050
Edit : That s about 2x the TDP of a LNL, so if the GPU is 2x bigger there s basicaly no improvement in perf/watt from N3 to 18A.
The GPU is on N3E.
poke01
4,704
6,050
Please. Measuring the at the wall is always perfect and is the correct way to measure power consumption
Abwx
11,991
4,946
I did specify what the numbers were, and they were picked as the closest option to the full-system power number that was provided by the PCWorld preview. Now it's entirely plausible that PTL will show higher or lower power numbers when subjected to the same process in full notebookcheck review, we're just ballparking at the moment.
As for the comparisons against almost two year old chips... well, that's what happens when the competition phones it in just like Intel used to. AMD's focus has moved on to AI. We'll still get table scraps, but their announcements at CES make it clear how much they care about consumer devices.
PCW say that they could tell us the TDP but then the guy say nothing about it, just that it s the max perf profile, beside he show the power at the main a few seconds on a random scene, not average during all the test, a sample of a few seconds for power is not representative, it can be a non demanding scene, but the fact that he say that it s max perf profile mean that the CPU TDP is likely the same than in Computerbase s test.
poke01
4,704
6,050
If the TDP is set to 60 watts for Panther Lake as a whole meaning the GPU can access 2x the power when gaming then it does invalidate the efficiency gain over lunar lake.
We will see
Hulk
3,968
Would have been some pretty good foresight if Intel could have had some Panther Lake with 32GB RAM on the die like Lunar Lake coming off the presses. Yes, I know some people NEED 64GB, but in general the unwashed masses (like me) only need 32GB and rarely if ever crack open the laptop case.
Abwx
11,991
4,946
We will see
That s the power for the whole chip whatever how it s distributed, beside in games the CPU power is much less than what is drained by the GPU, the CPU drain something like 10-15W at most for the stated 70W PL1.
poke01
4,704
6,050
Exactly so you’re saying we need wait tests on how it performs on lower TDPs over lunar lake and Strix point
Abwx
11,991
4,946
Since the GPU is much bigger there wont be much lower perf with half the TDP, it should still be quite ahead of LNL and 890M by the virtue of the SP count.
mikk
4,327
2,408
I wonder if any of the proper reviews for PTL graphics will include Strix Halo running at comparable power. Anyone aware of existing reviews for Strix Halo graphics which aren't running at 100W+?
The comparison points in notebookcheck's brief CES PTL preview, including external monitor Cyberpunk 2077 power numbers from the full reviews - https://www.notebookcheck.net/Intel...in-our-first-gaming-benchmarks.1200743.0.html
- Radeon 8060S: 92.1 fps, 195W
- RTX 5050: 75.2 fps, 129W
- Arc B390: 44.8 fps, 60W (according to PCworld preview, full system)
- Arc 140V: 28.3 fps, 45W
- Radeon 890M: 26.5 fps, 58W
Wccftech tested Cyberpunk with Strix Halo at 54W and Panther Lake at ~50W. Maybe Strix Halo at 45W is as fast as 388H at 45W if this game reflects more games.
In Cyberpunk 2077, the Intel Arc B390 iGPU delivered 99.45 FPS on average at 1080p using the Medium Preset and Balanced XeSS preset. The Strix Halo iGPU scores 111.92 FPS in the same benchmark at a 54 Watt TDP
LightningZ71
2,660
3,346
While testing at the mains is often a reasonable method, he is correct that many systems can draw power from both the mains AND the battery as needed. If you are doing that sort of test, you really need to tighten up your methodology. Among other things, it needs to be a LONG duration canned test, like at least an hour, preferably more. Start each system at 100% battery charge and verify the actual battery capacity at 100% listed as many only charge to only 85% of rated cell capacity and call it 100%. Then, you capture the draw over the test duration at the wall, and then add in the battery charge used during the test to find total watt/hrs consumed.
We did this at work years ago to validate manufacturer power efficiency claims on some commercial applications and found that, not shocking to anyone, manufacturers have fudged past numbers quite a bit.
For a handheld, I would wait for actual reviews of individual devices that detail how long you can play game X from a full battery and maintain 60fps at reasonable quality. So much comes down to actual device implementation.
Khato
1,344
427
Thanks! I'm so used to wccftech being a source for nothing more than random rumors and questionable news that I didn't even think of checking them for first-party results from the CES demo, haha.
Also appreciate the clear statement that despite the absurdly high TDP settings, actual PTL power consumption remained around 50W max. Matches what I know about PTL. (Again, you can set the TDP as high as you want, that doesn't mean the chip is going to use that much power.)
Reactions: 511 and DAPUNISHER
511
5,257
4,700
This is TDP not actual power consumption and people have taken reading from devices
511
5,257
4,700
You can't use this cheat on battery and PC world tested power draw on battery it was around ~60W System
ToTTenTranz
872
1,466
Hopefully, this means it's over for overpriced Strix Point and Phoenix in handhelds. Especially with AMD refusing to distribute FSR4 for RDNA3, the difference in performance for ISO IQ is enormous.
It's either Panther Lake or cheap Strix Halo. Finally, some decent performance evolution since 2023.
regen1
295
372
Computerbase Article Author's comment
Watt-meter @1:50 onwards, stays under 60W.
Quote from ETA Prime's video:
The next game I was able to test here was Cyberpunk 2077. And before we get into it, I do want to show you what we've got. So, this is a watt meter coming from the wall. And unfortunately, I wasn't able to use like hardware info to get a correct reading, but it does look like the TDP on this setup was at 65 watts. So, we're not quite drawing 65 watts even running Cyberpunk like this.
Yeah, this is just the configuration settings, not necessarily the power consumption. Even the HWinfo page from CB test shows just that, there's no readings/sensor page shown there.
Anyway we will get numbers from tests/reviews not that far away.
Reactions: poke01 and 511
regen1
295
372
Qualcomm and Intel battery performance claims/issue:
The story in short: Qualcomm had claimed about eight months ago that Intel is losing up to 45 percent of power in battery operation, which is not the case with its solutions. This number was not devised, it came about by a faulty firmware in a Dell notebook coupled with curious power profile. However, since the solution was exactly in the trade and could be bought by everyone, the accusation was valid and Qualcomm’s marketing decorated it accordingly.
The topic also made high waves for Intel, so that the question of ComputerBase went directly in this direction at the start of CES 2026 in Las Vegas: How should this be prevented and what will it look like in the future? Intel immediately made it clear that it was not so natural, the “normal loss of power” at Lunar Lake was on average “only” 14 percent when the power cable was removed.
The problem with this, however, was that the OEMs were able to interpret certain things very loosely and broadly, so that it could differ more here and there – that in turn was Intel’s miscalculation. Coupled with incorrect settings by the OEM, a worst-case scenario could be created as the one at Dell.
Panther Lake battery-performance claims:
Panther Lake is getting much faster in battery operation
For Panther Lake, Intel is now taking OEMs more into account. The power profiles are now intended to ensure that the power in battery operation continues to reach very close to that of the socket.
In a first short test on site, the performance was also at almost the same level in games, regardless of whether the notebook was connected to the power or on the road in battery mode.
Reactions: Schmide and 511
Hulk
3,968
"I wasn't able to run any CPU benchmarks right now."
Hmm.
Magio
202
240
Really hope NVL is a return to serious CPU gains because it's been a rough couple of years with peak performance basically plateau-ing since Raptor Lake with the only gains since coming in the form of efficiency.
On another note, leaving aside CPU and GPU metrics one area where PTL's launch is a huge success IMO is in the sheer quantity of *quality* and distinct designs from all major OEMs. Intel's partners truly brought their A game to complement Panther Lake and it's just the start.
