Page 899 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
906
828
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Magio
188
231
ARL-H was 40K .. and this has 1.5X Cores and higher frequency
Still, you're not getting 50% increase in perf at equal thermal envelope just from going from N3B to N3E. And arch improvements are more likely to materialize in game performance than in synthetic benchmarks. So 25% from N3E + wider GPU seems reasonable, until we learn more about TDP and how performance scales across that line.
Benchleaks has shared a few more results since, with a 53000 best score. Hoping we get first CPU results soon.
Reactions: DKR
511
4,971
4,498
ARL iGPU is N4P
Reactions: DKR
dullard
26,130
4,784
At 2.5 GHz, that is 5% to 30% higher frequency than Intel iGPUs usually run. I don't remember any mobile iGPU running faster than 2.35 GHz. The equivalent lower Ultra 7 Lunar Lake (258V) was 1.95 GHz.
There were actually 8 iGPU benchmarks done on the 358H. Here is the best vs. the worst:
And here is a 358H benchmark vs the best 258V Lunar Lake score that I could quickly find in a roughly equivalent ASUS 14" laptop (67% higher for the 358H):
Reactions: DKR
eek2121
3,434
5,088
Looking forward to some actual gaming benchmarks!
And my point is this is the behavior of value seeking users, not people who buy very expensive laptops and dual 5k monitor setups. I understand there's a use case for people who want just one device (due to personal choice or work conditions) but the overlap between these people and the "dual 5k monitors + M2 external storage" is slim to none IMHO. The value seekers are fine with USB-C, TB is nice to have for them but may only be available out of their comfort range.
And the external M2 storage via TB is more useful for business users?
Meh, I don’t know about multiple 5k displays, but my “ancient” Zen 3 laptop has no issues driving the Apple Studio display.
I don’t think I have ever worked at a place where they gave you “premium” monitors. Nearly all of them bought cheap 1080p monitors for everyone.
Reactions: DKR
dullard
26,130
4,784
First Arrow Lake Refresh benchmark is now out.
Looks to me like the Ultra 7 270K is the Ultra 7 265K with 4 more E cores and a slightly lower base clock. Videocardz calls it the Ultra 9 285K with a lower turbo clock. Either way, it is in between the 265K and the 285K based on specs.
Memory speed gets a boost from DDR5-6400 to DDR5-7200. That'll be relevant to the vast majority of computer users who don't upgrade CPUs on the same motherboard. The 270K Seems to perform MT a few percent better than the 285K in an almost equivalent system (memory speed changed).
ToTTenTranz
797
1,289
oh no, not in video games it ain't
The 140V is faster than the 890M in every game that was picked up by Intel's driver team. And many of these results should be outdated as Intel has been making strides in their drivers pretty regularly.
It's also interesting to see the 890M's anemic bandwidth at play, where it starts much faster than the 140V at "ultra low" settings but at high it becomes slower. The F1 results are impressive.
Magio
188
231
It depends, it does better in some, worse in others and similar in many. 140V does usually do it at better efficiency which means that in similarly thermally limited conditions it's the better pick.
What PTL looks to do is make it a concrete win at LNL-level TDPs while having a lot more upside at higher draw which really should make it not a contest anymore in any conditions.
DavidC1
1,993
3,140
Yes it does, not only that, it's even better in handhelds, meaning power constrained environments.
That's why ISO-ing always matters. Cause otherwise you can compare it with 600W RTX 5090.
It can't be bandwidth only, because in Time Spy, which represents very demanding low fps scenarios, the scores go from 62xx using 8533MT/s to 63xx using 9600MT/s. By that figure, Pantherlake can perform 30-50% higher than that before it even starts reaching the level equal to normal GPUs, nevermind bandwidth constrained ones. Intel's normal iGPUs were never really bandwidth constrained, unless you suddenly dropped to single channel, or 2x'ed it like Iris without eDRAM.
It could be other factors at play with F1 2025 as well. Weaknesses of ARC graphics does carry a bit into their iGPUs as well. It's typically weak in GTA V, and in NBC test, even 140V is.
Reactions: DKR
MS_AT
896
1,798
Not to nitpick, but can you show where in this techpowerup review comparisons are made against 890m? AFAIK both handhelds they are comparing against are using zen4 chips. It is also worth pointing out that competing devices have half the RAM.
hemedans
294
165
Phawx also have plenty of benchmarks
Reactions: coercitiv
coercitiv
7,441
17,727
Notebookcheck's data is difficult to compare directly. For the 890M they tested gaming performance even with NUCs that use DDR5 5600MT/s. Even when the mem bandwith is theoretically the same, results vary greatly from one device to another.
To be clear, I'm not arguing this would make the 890M more of a winner, just pointing out evaluating the 890M needs more effort there or a more consistent source.
DavidC1
1,993
3,140
Only way for Pantherlake to be slower than 890M would be if Intel regressed. Those are also based on TDP settings, where in the platform level, Lunarlake is lower power than Meteorlake and Strix. So far, if there are weaknesses, graphics doesn't seem to be one.
Also, doubling of the GPU cache means it has 16MB, which is same as Infinity Cache of 6500XT. Someone was talking about how 890M could have fit 16MB if it wasn't for the DWU? Well... it seems we got an Intel version.
Reactions: DKR
MS_AT
896
1,798
I don't recall mentioning Panther Lake anywhere. I just asked where are the supposed comparisons between 890m and Lunar Lake GPU in the techpowerup review you linked. That's all. I think it's a very precise question, you can link to a page from the review where the comparison can be seen or you can say that the review does not compare them. I just wasn't able to find it myself, but I might have missed something.
LightningZ71
2,616
3,302
the 6500XT had 18Gbps ram at 64 bits giving 144GB/sec bandwidth.
If Panther Lake is configured with LPDDR 8666 ram at 128 bits, it'll have 138 GB/sec bandwidth. any faster and it'll match or surpass the 6500XT.
I dare say that it'll be quite a disappointment if the iGPU on Panther Lake isn't capable of putting up numbers that are in the immediate vicinity of the 6500 XT on most gaming benchmarks. Depending on the game, and excluding any raytracing, the 6500XT is anywhere from 10+% to 20+% faster than the 890m at 1080P High.
Personally, I expect Panther Lake to slot in a bit above mobile 6500 XT specs and performance, with the ability to enable a few of the les demanding ray tracing features. It should do even better when both have XeSS / FSR enabled.
