Page 853 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
846
799
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
OneEng2
840
1,105
I do not have to admire it nor follow the delusions of Skymont messianic cult. It's Zen 4 but without the ability to clock high nor support AVX-512 instructions a few years later on a better process.
One on one, Zen 6c will most certainly overpower Darkmont IMO. Everyone keeps calling foul on SIMD instruction use and SMT. Seems fair to me. Use what you got in your architecture .... and lots of programs do. I can't buy into the idea that you have to benchmark E cores where they work best.
It will prove delusional. The ILP wall comes for all its descendants all the same. And at the end of the day Skymont will always be Skymont, not its children.
The thing I keep coming back to is that should you add good SIMD support, SMT, and all the associated plumbing needed to do those things, Skymont would likely look much more like a P core does today.
18A CWF Darkmont is about 25% more cores in given area than N3E Turin D Z5C when excluding LLC.
Good enough. Seems it all comes down to clocks.
Considering that there is an expected 20% transistor density improvement going from N3E to N2, seems likely that Darkmont might be about the same size as Zen 6c. While Darkmont is going to have AVX10, it is only going to support a 256 bit data path vs Zen 6c's full 512 bit data path. So while it will do better (much better) than Skymont, it is likely going to get seriously beaten about the head and shoulders by Zen 6c in real-world workloads IMO.
Just the lack of SMT will leave Darkmont at a 40% per core deficit to Zen 6. With this kind of deficit, it's going to take a lot more than 288 darkmont cores to best the 256 core Venice D (Zen 6c) IMO.
511
4,523
4,144
You are dead wrong on this one the area is roughly the same between Skymont and darkmont for 1.1mm2 Core+L1 and Turin Dense to Venice Dense should keep the area same imo they are not doing a big node shrink.
Kepler_L2
998
4,263
What's Zen5C size on Turin-D?
511
4,523
4,144
The base Dies are ~350mm2 for Clearwater quite smaller than ~598mm2 GNR Die and the 18A chiplets are 55mm2
Reactions: DKR
511
4,523
4,144
Intel need a good L3 Team they cooked the fabric in ARL/MTL. GNRs was slow and looks like Clearwater Forest is not enough to overcome the BW Bottleneck.
gdansk
4,568
7,682
That a high end product selling for a premium price, so packaging cost is much less of a factor. Plus each CCD has 8 Zen 5 or 16 Zen 5c cores so it is much much larger than the tiny little one core dies Intel is using. Totally different economics.
Oh, no, maybe something was missed here. This is a server chip being discussed in the Lakes thread for some reason. It's 12 x 24 core dies. The dies are tiny because Darkmont is indeed pretty small when the LLC is in another castle.
lightisgood
250
121
86
CWF's cache-arch is not clear yet.
For example, I don't know how much there are mesh-stops in a compute-tile, you too.
coercitiv
7,355
17,424
Turin is obviously cheaper to package but we're still looking at 16 chiplets for the vanilla cores and 12 chiplets for dense. The Intel tiles also lack L3 as @gdansk already mentioned.
That being said, Intel has this tradition of never adopting the straightforward approach of the competition. With the P cores they insist on those huge tiles, with the E cores they went the opposite way of breaking everything into multiple small pieces. The only thing constant about an Intel product is cost, they're always expensive to make. :p
PS: imagine if Intel had a tile strategy on the consumer side that would allow them to plant one of these 55mm2 Darkmont tiles in a desktop product. Too much sense? /s
Doug S
3,574
6,311
Ah, I missed the mention of "Xeon" in the last line of the bullet points that mentioned the 12 chiplets. I gave up years ago even trying to keep Intel's stupid code names straight. Since people were talking about that Panther Lake chip made on 18A for industrial type markets that was recently released, I thought that's what this was!
Glad to know the world hasn't gone crazy without me noticing and Intel isn't building chips with single core chiplets!
Reactions: Tlh97 and coercitiv
511
4,523
4,144
Yeah the Mesh stops are not clear but they will be 24 For the cores+ 4 for IMC + 2/4 For EMIB?
511
4,523
4,144
PTL won't have this L3 Issues cause there are only 6 Ring Stops for the Cores and 1 For IMC I guess.
