Page 852 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
856
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,364
4,771
What do you mean? The tweet clearly says Skymont is 3.18, RPC is 3.71. I remember Intel hyping up "Chadmont" saying it was going to have Raptor Cove +2% IPC. This tweet is saying Darkmont has Skymont+17% IPC and now Darkmont is equal to RPC, lol.
Also in the tweet SRF is Sierra Forest with 3.18 is Crestmont
coercitiv
7,464
17,829
I'd take this tweet with a grain of salt. The 17% number on the Intel slide is SpecIntRate, i.e. one specInt instance for every hardware thread. All the numbers in the tweet (except Darkmont) are specInt.
At the same time, it does provide us with a baseline for perf/clock uplift, and that baseline does not look particularly optimistic given the double digit difference we know exists between Skymont and Crestmont. I agree though that going for the RPC comparison is... not a great idea.
Ah, thought it was Skymont. So, Darkmont is < Skymont. Odd.
We would need to know relative SpecIntRate for Skymont/Crestmont in a similar server architecture, otherwise math goes sideways fast.
Reactions: Covfefe
Covfefe
93
166
66
I don't think it's useful even as a baseline estimate.Here's some SpecIntRate results for the 5 CPUs from the tweet.
SpecInt “ipc”​
SpecRate score​
copies​
score per copy​
clockrate (nominal)​
SpecRate “ipc”​
specintrate link​
Emerald Rapids(RPC)​
14.5/3.9 = 3.71​
1240​
256​
4.84​
1.9​
2.54​
link
Granite Rapids(RWC)​
13.6/3.9Ghz = 3.48​
1220​
256​
4.76​
2​
2.38​
link
Sierra Forest(SRF)​
9.54/3.0ghz = 3.18​
1410​
288​
4.89​
2.2​
2.22​
link
AMD EPYC 9654​
14.3/3.7 = 3.86​
1790​
384​
4.66​
2.4​
1.94​
link
AMD EPYC 9755​
18/4.1 = 4.39​
2720​
512​
5.31​
2.7​
1.96​
link
The SpecRate ipc I calculated here is obviously next to useless because the real world clockspeed could be miles apart from the nominal clockspeed. Despite that, I think the SpecRate score and score per copy is enough to completely discredit the tweet's comparison. SpecRateInt and SpecInt should not be directly compared.
desrever
337
826
SpecInt “ipc”​
SpecRate score​
copies​
score per copy​
SpecRate “ipc”​
specintrate link​
14.5/3.9 = 3.71​
1240​
256​
4.84​
1.9​
2.54​
13.6/3.9Ghz = 3.48​
1220​
256​
4.76​
2​
2.38​
Sierra Forest(SRF)​
9.54/3.0ghz = 3.18​
1410​
288​
4.89​
2.2​
2.22​
AMD EPYC 9654​
14.3/3.7 = 3.86​
1790​
384​
4.66​
2.4​
1.94​
AMD EPYC 9755​
18/4.1 = 4.39​
2720​
512​
5.31​
2.7​
1.96​
You are comparing SMT scores and dividing on it???
coercitiv
7,464
17,829
Yes, I know it's a bad comparison. That's kind of my whole point.
Let's look at a very crude "efficiency" metric, SpecRate "IPC" / SpecInt "IPC":
SpecInt "IPC"SpecRate "IPC""Efficiency"
Emerald Rapids(RPC)
3.71​
2.54​
0.68​
Granite Rapids(RWC)
3.48​
2.38​
0.68​
Sierra Forest(SRF)
3.18​
2.22​
0.70​
AMD EPYC 9654
3.86​
1.94​
0.50​
AMD EPYC 9755
4.39​
1.96​
0.45​
Seems to me like arches from the same family that use similar interconnect tend to have a degree of semblance when it comes to scaling from SpecRate to SpecInt. It's not enough data to draw a conclusion, but not a chaotic comparison either.
Reactions: Tlh97
Doug S
3,805
6,736
Am I reading those slides right or did Intel marketing write them stupidly?
Are there actually 12 separate CPU chiplets, mounted four at a time on three base tiles?? If so, holy chiplets Batman!
Doug S
3,805
6,736
Wow my understanding of packaging economics must be out of date because I can't see how that can possibly be cost effective? Ditto dicing wafers into tiny little E core sized chiplets. I haven't followed what Intel is doing that closely (obviously) but this seems crazy to me.
I guess it is good if you have crappy 18A yields though...
Josh128
1,510
2,262
18A CWF Darkmont is about 25% more cores in given area than N3E Turin D Z5C when excluding LLC.
Good enough. Seems it all comes down to clocks.
How does that jive with 18A claimed density vs N3E? I know its apples to oranges, but Im guessing Darkmont has significantly more transistors than Crestmont, so maybe ballparkish to Zen 5C?
gdansk
4,742
8,030
It's beyond apples and oranges. I can't say anything useful about the processes from measuring die shots.
Saylick
4,114
9,618
Source link is broken.
Also, I wonder what the core-to-core latency plot will look like, specifically when one core needs to talk to another core on a separate die but on the same base tile and on a separate die but also on a separate base die.
Then again, the use case for a product like this doesn't really necessitate low core-to-core latency so... eh.
Reactions: Tlh97 and coercitiv
adroc_thurston
8,342
11,104
Characteristically the same as GNR, where local L3 is slow but manageable and far L3 is pretty bad.
Reactions: Kepler_L2
DavidC1
2,124
3,255
The 17% is useful on the basis that we could take the SpecIntRate score from Sierra Forest, multiply by 1.9x for typical clock scaling with double the cores and do 1.17x on it. Which would be 3140 for Clearwater Forest.
I think they are doing this for two reasons:
-It hides how the final part performs
-Multi-thread performance is the most important metric for Clearwater Forest
The other issue in using Rate is that "IPC" for MT in comparison to SMT enabled cores is affected significantly by SMT. So if AMD benefits more from SMT, then the SpecRate "IPC" would look better for AMD versus if you used 1T SpecInt by a few %.
Actually, Darkmont is only few single digit % faster than Skymont, which will be easily eclipsed either way by SoC implementation. So the real important part for Clearwater is how the part performs against predecessor and competition(including Intel) in actual server workloads, and in SpecIntRate.
Sierra Forest needed Intel comparing a 144 core SRF against 128-thread AMD part. If it gets over 3000+ for 2P, then it can be directly compared against top 192 core AMD part. That wasn't good for Intel as they have to sell it as a perf/W and perf/$ and you need a high end part for more revenue.
Reactions: Tlh97 and Joe NYC
Joe NYC
4,161
5,706
Yeah.
And two I/O caps.
It will be interesting to see these 288 cores all accessing the shared 500 MB LLC through the mesh interconnect, up to 2 hops over EMIB.
OTOH, AMD has fast L3, 128 MB per chiplet (1 GB per CPU), hiding all the L3 access traffic from the fabric...
