Page 841 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Fjodor2001
4,592
739
if you cut that 4+8 in half ut becomes 4+0/8+0.
I suppose you mean it becomes 4+0/0+8?
But is it really possible to cut it like that and still get usable dies. I added some red lines in the picture. Do you mean it should be cut along those red lines, or some other way?
The 4 P cores would be on two separate dies after the cutting then. :confused:
Wouldn't cutting it in the middle to get two 2+4 dies be a more logical option instead?
511
5,413
4,833
So the layout is a bit changed 2P Cores Shares a L2 Slice and also this is how i expect NVL Die Layout
DKR
21
34
51
IDK about SKU but the plan to make 4+8 using 18AP is canned it is using TSMC N2 now
Are you 100% confident about this? Because they already have a 4P+8E die on 18A for PTL-H? so it shouldn't be a big deal do that in 18A-P to do the same considering its just a related + node. At least what is what I thought. Also NVL is already taped out by the time Foundry direct connect 2025 event & shortly afterwards semiaccurate reported NVL SKUs on N2 taped out, I highly doubt Lip Bu Tan could have changed something on NVL by then.
Just from engineering POV to reduce engineering effort, to leverage tile arch & benefit from it, it makes sense to do one 8P+16E die on N2P & one 4P+8E die on 18A/18A-P. Then they can mix and match to create SKUs & down bin the 4+8 die to 4+4 & 4+0.
Note if 4+8 die is on 18A/18A-P, the entire mobile line up on NVL- H will be IFS (like PTL-H but on 18A-P), only the NVL-HX (8+16) will be on TSMC. I think this is very important for Intel to regain their margins. So it just baffles me that 4+8 would be on TSMC & that decision being made Lip Bu doesn't sound right with me. He is looking to be bean counter when it comes margins based on recent news about new product being approved only if margin >50%. Intel can't afford to keep outsourcing their products and maintain upkeep of their foundries which are fixed cost business.
This aligns with past commentaries from Pat & Michelle also that NVL is predominantly IFS based (Pat quoted >80% iirc) and only one top end SKU is on TSMC node. Also why MLID is keeping the 4+8 SKU as "high confidence" color instead of "very high confident" color. He is intentionally downplaying 18A-P imho.
I think Intel is only sourcing the 8P+16E bLLC die from TSMC. With that they can make a 2(8P+16E bLLC)+4LPE SKU for a Core Ultra 9, (8P+16E bLLC & 4P+8E[18A-P])+4LPE SKU for Core Ultra 7 & (8P+16E bLLC)+ 4LE for Core Ultra 5 that covers all the gaming crowd requirements of a bLLC SKU to compete with x3D. All these will be K SKUs. All the rest of the main stream K & non K SKUs will be based on 18A-P tiles like 2(4+8)+4LPE, 4+8+4LPE, 4+0+4LPE. This way they limit the outsourcing to TSMC to the minimum. This is just speculation on my part but who knows what is really going on at Intel now!
Reactions: OneEng2
511
5,413
4,833
Yes 100%
Reactions: DKR
511
5,413
4,833
Why are people making out about ~30mm2 extra die as bad defect rate its still < 150mm2 not a reticle size die also as DavidC1 said Cache aka SRAM can be worked around for bad yield using redundancy
Reactions: DKR
fastandfurious6
931
1,070
this is the probable future for intel/usf, keep top-end chips on TSMC latest nodes and keep less performing on their overpromising underdelivering intel nodes
511
5,413
4,833
Well at least they can do that what can any other company do? 🤣.
They can change plan based on Internal/External nodes what can other Fabless do pay 10%-20% more.
511
5,413
4,833
Wow, that's worse than I expected...
Well, goodbye Intel Foundries. You had a good run. Don't worry, Intel Product will be following you pretty soon...
LoL you know that there is no NVL without IFS/18A/Intel 3/18AP?
Magio
206
243
Compute tiles are the most important barometer and the fact there'll only be one of them made on 18A for NVL is a terrible sign. And combined with all the other bad omens including the CEO outright saying they're considering canning 14A... Yeah Intel Foundry's on its way out.
511
5,413
4,833
CEO was talking about financial viability of 14A not technical viability. Their issue is more financial than technical maybe it is due to the CAPEX cut he is doing
511
5,413
4,833
They are a large % of the die. Lithography flaws in cache can still disable a die.
so for example let's say 100mm2 is die size for 8+16 non bLLC and 130 is for bLLC it's not a large die size this is still a relatively small die
Magio
206
243
Doesn't really matter why LBT is considering dropping 14A and cutting-edge node development in general. Just matters that he is.
511
5,413
4,833
LOL
when Intel changes products from 18A/AP to N2 - 18A is sh**
when Intel gives up foundry due to money problem - doesn't matter
LightningZ71
2,688
3,383
The part that should concern is that Intel has chosen the least performance, smallest possible CPU die for 18A only. It would be one thing if this was the very first part they've ever done on 18A, but isn't Panther Lake, which is also supposed to use 18A supposed to have been in full rate production and general sale for a good 6 months+ by that point? Either they have very little confidence that 18A can hit the desktop performance targets they need, or they will be massively capacity constrained and will only make what can get high volume on that in house mode.
