Page 838 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Geddagod
1,680
1,715
It matches MTL (Intel 4)
I was talking more about the relative Fmax of the new node vs the Fmax of the older, more mature node.
So for 10nm it would have been Fmax of ICL vs Fmax of 14nm products, For Intel 4 it would be Fmax of MTL vs RPL, and for this it would be Fmax of PTL on 18A vs ARL.
18AP aka NVL Fmax is still ain't decided just like PTLs so taking a safe bet or so to say backup plan
Traditionally the "+" nodes have been very good at fixing Fmax problems.
And lets not forget, 18A-P isn't just the first plus, since 18A is just a large "+" over 20A too.
At some point it has to start becoming less about the "backup plan" and just knowing when your node is worse lol. Maybe it makes sense for ARL, maybe there's even a chance for PTL, but by NVL this is the 3rd generation of the 20A base node...
jpiniero
17,179
7,563
I have trouble believing IFS can continue to exist on legacy nodes alone. Sooner or later their own products wouldn't require those nodes, and if they struggle to compete in the foundry space at the cutting edge I don't fancy their chances on mature nodes.
If they were serious about being a third party foundry, that would be a big part of the plan.
511
5,437
4,864
What would you call RPL vs ARL with -0.5 Ghz?
The nodes have to enter into a decent volume they need to run a good chunk of wafers. I don't know how much dev effort was put into 20A before jumping to 18A cause Intel 4 was fully completed did they abandon the 20A half way or what Ice Lake(10nm+) shipped worse than 14nm++++ in terms of frequency TGL was solid improvement.
20A never had actual volume materialize so I don't know if you want to call 18A a (20A+) it shares the dev effort for sure but it never launched not a single broken product to call it a node .
If Node development is so easy and predictable why don't every company do it lol no one knows ahead of time how a particular node is going to turn out It's a good thinking on Intel Product's part regarding their planning.
TSMC did a similar thing N2P was supposed to have BSPDN but they cut the BSPDN for later a minor improvement on N2P (~2-3%) over N2 according to TSMC and A16 get the BSPDN.
Geddagod
1,680
1,715
More of a difference between Intel 18A and Intel 7 lol.
They didn't ship any 10nm silicon either. CNL was a meme.
18A should be equivalent to 10nm+, and 18AP to 10nm SF.
Besides, I thought you said 20A was canned due to costs, and not due to development?
No, its them knowing 18AP is worse than N2 by a good bit.
Again, you can't call every time Intel goes external as them "risk mitigating" lol. 18A-P is just more mature 18A, there is no risk there.
It's good thinking for Intel products to use a better node.
Geddagod
1,680
1,715
What is this even a similar thing to lol
vanplayer
78
121
66
These people are just guessing and nobody nail down the frequency, internal target down from 5.4-5.5 to 5.0-5.1
also someone mentioned the density is comparable to N4X which is similar to what I heard last year, to be precised and AFAIK, Panther P core cluster is less dense than Granite Ridge Zen5 core cluster. I can't provide a number here but it's relevant to MTr/mm2.
Reactions: Joe NYC
511
5,437
4,864
Yes and running wafers costs money
Lmfao Intel 3 is more than par with N4X in density 18A has density in the same ballpark as N3B which is the densest N3 node in terms of CPU design using HP libs.
msj10
114
118
you said NVL bLLC doesn't exist a few days ago which is complete BS.
Joe NYC
4,208
5,816
I was trying to figure out transistor density of either Arrow Lake or Lunar Lake compute die - with no luck. Any ideas / estimates?
511
5,437
4,864
18A HD is as dense as N3E HP from cell area. I think it's safe to assume it's less dense. Real question is just how bad is it.
Whoever told you this is freaking lying it's slightly smaller than LNC on N3B N3E HP 3-2 is less dense than 18A HP
More than on par? It's on par at best given how RWC looks like.
RWC doesn't uses HD Libs classic Intel.
Reactions: DKR
vanplayer
78
121
66
Sometimes I thought it's not the node's problem, but it's the design that being problem, Intel's whatever CPU and GPU being less dense than competition even when on the theoretical competitive node.
The example is Intel7 loses 40% density compare to on-paper number when it's on Alderlake, another example is Battlemage's PPA is terrible.
¯\_(ツ)_/¯
Reactions: booklib28
511
5,437
4,864
The example is Intel7 lose 40% density compare to on-paper number when it's on Alderlake, another example is Battlemage's PPA is terrible.
Yeah same thought many times though for the CPU Core the density was fine for the other stuff it ain't fine
poke01
4,855
6,185
I wouldn’t fully trust rumours regarding Panther lake, too many vultures circling Intel. Just gotta wait and see from Intel themselves
Geddagod
1,680
1,715
Wikichip
48 x 169 = cell area of 8112.
Intel 18A HD cell area is 50 x 160 = 8000.
Pretty much the same.
Very little difference between HD and HP Intel 3 density. Not much cell height scaling. Similar to 18A in that sense.
What they said wasn't even that bad lowkey
Joe NYC
4,208
5,816
¯\_(ツ)_/¯
I agree with this.
And then all the discussion about theoretical density are moot. If the only product on it Panther Lake and that design can't reach this density, not even close, than what's the point of discussing it?
BTW, does Panther Lake compute tile include memory controllers or only cores? The reason I am curious is if we can even theoretically get a good measure. Because inclusion of memory controllers would likely dilute the transistor density...
511
5,437
4,864
It includes Memory/Display Controller Media engine P/E/LP-E Cores and die waste unit
Reactions: Joe NYC
OneEng2
1,004
1,209
His primary objective is stopping the bleeding of cash and actually helping Intel turn a profit. The mess created by Pat is just too insane:
trying to sell existing Raptor Lake inventory (even Alder Lake is still not sold out),
dealing with RPL RMAs,
Intel 7 still being a harsh reality to deal with because those fabs were not converted to Intel 3 or 4,
trying to woo back OEMs because Pat's decisions led them to look to AMD to fulfill their mobile products demand,
trying to trim Pat's fat engineering teams to make them more lean and agile
and so many other problems that are probably not even public and which contributed to Pat's sudden termination.
IMO, his worst mistake was ignoring the exponentially rising cost of lithography processes and machinery and attempting to compete with TSMC's volumes at a fraction of their volume.
People keep assuming that it is less expensive for Intel to make its own chips on 18A when Intel put over 20bn into the development of that process (as I have said before, this is as much as a Ford class Navy aircraft carrier).
This is simply unsustainable ..... even IF 18A would have achieved parity with N2.
NVL will likely use 18A-P, so if Fmax gets fixed, how does outsourcing to TSMC still make sense?
It is likely less expensive to make chips on 18A/18A-P only if sunk costs are ignored. My guess is that the performance and yield and volume are lacking. This not only leaves TSMC making sense, it likely leaves it as the only option unfortunately.
I am not certain that it makes any sense from a financial standpoint. New process tech development has become exponentially more expensive and more difficult to get right.
It is my understanding that BSPDN allows routing efficiencies of ~30% that are not included in the raw density calculations.
