Page 723 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ajsdkflsdjfio
185
133
They might be clever enough but I was referring more to Intel's "excuse" that AVX-512 can't work with E-cores enabled. A hardware/software combination of "trap AVX-512 instruction and context switch over to P-core" could've been done if they hadn't been lazy and so sure of themselves.
If they had been so good, they could've put in the extra effort to keep AVX-512. Haven't heard of Zen4c/5c?
From your words here, one would assume you are talking about Intel e-cores and them not having AVX-512 support.
19,218
AVX-512 for Alderlake and subsequent generations didn't work because of architectural problems
First I'm hearing of that. Did you miss the AT review and other reviews where they TESTED ADL's AVX-512?
Now look how pathetic 13900K is performing without AVX-512:
They could've been a clear 2nd place winner with Raptor AND Arrow.
Guess what all those people with AVX-512 software did? They turned AMD and for the foreseeable future will REMAIN there. That's Intel for you. Ditching their advantage and feeding marketing cores to their "sheep".
Reactions: Tlh97
Thunder 57
4,294
7,100
Idiot Lisa should have given it a ounce of thought before going all in on AVX-512. Now it's all going to go down the drain.
On Amazon? :tearsofjoy:
Idiot Lisa that has outlasted, what, three Intel CEO's now? :rolleyes:
Oh. Thats amazing. Intel should have thought of that.
Do you realize how much latency it introduces?
Clearly Intel did think of it or they never would've wasted die space by including AVX-512.
19,218
You could say both. Intel after Ice Lake behaved like a beginner swimmer trying to navigate murky depths. Just such a sad waste of engineers and their talent.
ajsdkflsdjfio
185
133
You yourself liked this post, which referred to scheduling difficulties surrounding AVX-512 only being available in P-cores and general AVX-512 problems architecturally.
Also It's funny how in those graphs rocket-lake and zen-4 demolish Raptor lake without AVX-512 in those workloads, but in the real world rocket lake is a piece of dogshit under the boot of Alder/Raptor and Zen4 still loses in 90% of applications. Goes to show my point that Intel's decision to cut AVX-512 support did not affect their product's competitiveness at all, not just for intel "sheep" but for consumers in general.
Reactions: Grazick
Win2012R2
1,327
1,367
How about 200ns of latency
AFAIK faults/traps will take a lot longer than that, been a while since I looked into it though...
Now they're coming out with AVX10 which is not binary compatible with AVX-512. So, good luck to AMD
Any AVX-10 capable CPU will fully support "legacy" AVX-512, so most (of very small number capable of doing it) programmers will just stick with AVX-512
Reactions: Kryohi
ajsdkflsdjfio
185
133
I liked the part where he stated that it's not realistic to expect E-core to outperform P-core with a few tweaks. That would require a pretty serious redesign.
Understood and agreed, regardless it's not entirely apparent that AVX-512 implementation didn't have drawbacks in Alder Lake, also Intel disabling it did not affect majority of consumers. It's not a "stupid" decision for Intel themselves and also not a decision that can be put on Pat himself.
Win2012R2
1,327
1,367
But AVX10 instructions & AVX-512 aren't binary compatible or backward/forward compatible.
They intend to support AVX512 on AVX10 capable processors - "The Intel AVX-512 ISA will be frozen as of the introduction of Intel AVX10 and all CPUID feature flags will continueto be enabled on future P-core processors for legacy support."
Source from Intel - https://cdrdv2-public.intel.com/784343/356368-intel-avx10-tech-paper.pdf
That's the theory, not sure how that will work on AVX10/256 - they will have to use AMD style double pumping to keep AVX512 working (though 256 might mean registers are only 256 bits in the first place, so can't do AMD stylee), this whole AVX10 thing seems to be a big mess that is unlikely to take off anytime soon.
It's going to be 100% dead in the water if AMD says that they won't support it anytime soon, if I was them I'd do just that
A bit smaller? Likely yes.
A lot smaller? Nope.
Intel's AVX512 implementation is hillariously inefficient - we can certainly say that now seeing how good AMD did that in Zen 4 and now 5 - no more excuses - "it's double pumped half speed stuff!" Only thing AMD is missing is 64 byte/cycle from L3 to L2/1, that's definitely a flaw but hopefully fixed in Zen 6.
Win2012R2
1,327
1,367
Things would have worked out differently for AVX-512 (and AMD) if 10nm was on track...
That means, it should take somewhere around ~25% to ~30% of the current Skymont core if included.
It's also likely that power requirements (and thus heat) for this block are such that satisfying them would make whole Skymont design far more difficult - bigger, Skylake had to spend like 50k cycles to "wake up" AVX-512 otherwise even in fat core there were issues with power delivery or somesuch.
Reactions: ajsdkflsdjfio
ajsdkflsdjfio
185
133
Anyways, it's a ton of work for a edge-case feature on a consumer only product. If they want to add AVX-512 they should add it to Darkmont for server, but it looks like they aren't. AMD is doing the same thing, they didn't add AVX-512 to Zen4/5 to push consumer AVX-512 adoption, they did it to bolster their datacenter products since they use identical architectures pretty much.
