Page 711 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ajsdkflsdjfio
185
133
IDK why they can't do like a test without all the updates and with the current available updates and give a solid average over 50+ games or something like that. This performance improvement table is so vague...
Also even with a +10% performance improvement, the damage has been done with arrow lake's mindshare already.
Hulk
4,115
Because it's all BS. ARL is what it is. It's not terrible, it's not great.
ajsdkflsdjfio
185
133
They have like multiple 2-14% improvements and a 6-30% improvement like what are we expected to extrapolate from this data. I'm also thinking it might be BS in which case this is a horrible look for Intel.
Reactions: Nothingness
DAPUNISHER
32,435
33,440
LMAO never say that
We did just see 30%+ performance improvement in Cyberpunk. Ergo there are places where arrow lake can be massively improved, yes?
gdansk
4,792
8,084
ajsdkflsdjfio
185
133
It's not 2-14% or 6-30% overall improvement. He said in some specific cases (due to misconfigured motherboard bios from some vendors), there were slight to significant performance drops and it varies from vendor to vendor and model to model. This fix is supposed to address many such issues. Fixing these slight performance drops to significant ones, brings the overall performance across different motherboard vendors to expected levels, which they earlier mentioned is in upper single digit over previous gen.
He also mentioned that there is one brand new update "in-flight" that's expected to bring additional performance uplift (probably around +5% for games). Bringing the overall ARL-S performance to around ~10% over previous gen.
Yea I didn't assume it was, which is why I said they should have done a before vs after with a bunch of games/applications and taken the average to present to people, because 2-14% or 6-30% in specific scenarios tells us absolutely nothing. It just looks like they're trying to mislead people when they give vague performance numbers like that.
Reactions: Hulk
Hulk
4,115
Have you ever seen "Apocalypto?"
Perhaps we should start referring to Intel as "Almost."
19,218
They will publish a "performance digest" at CES showing what final ARL performance should look like after everything is patched. But overall, Hallock was more concerned about the wild variations in figures gotten by various reviewers than trying to paint the CPU as being competitive with its competition. So after all is said and done, it may still end up being boring. Just slightly less than before.
I read about someone hitting 9000 MT/s memory speed at Gear 2 comfortably. That's really nice but even that isn't supposed to give more than 15% extra perf in bandwidth starved situations and most likely only a few good bins will be able to go that high.
Reactions: ajsdkflsdjfio
alcoholbob
6,390
470
Previous gen as in Meteor Lake? I thought Hallock originally said the entire patch was supposed to just bring us the performance they promised from the initial slides - which was *almost* 14900K performance.
coercitiv
7,489
17,901
Thinks of it this way, there are workloads where ARL behaves unexpectedly bad, so bad many consider them outliers. That's where I expect to see double digit improvements. Those workloads, while important for some users, won't budge the needle much in terms of average performance, so the end result is still going to be single digit uplift.
Hulk
4,115
Exactly. If these were significant changes Intel would have provided data showing specific applications and workloads with before/after performance numbers. All of this "data" is couched in a blanket of purposely obfucated language. I wonder if the hours expended into the investigation of finding and correcting issues were equal to the time spent in trying to figure out how to disseminate what was learned in the best possible light and how to shade the findings that were especially negative to ARL architecture.
Reactions: Thibsie
511
5,481
4,895
The architecture was pretty horrible tbh no wonder Meteor Lake S was scrapped and they are going back 2 drawing board with PTL/NVL
511
5,481
4,895
One of the key problems are those 2 silly Crestmont LPE cores in the MTL SoC tile (low power island). They're so horrible they caused more issues than they solved. The numbskulls at Intel should have at least given us a BIOS option to disable the LPE cores if we wanted. Would have solved a ton of the issues.
Or they should have made 4 cores like LNL to actually matter
Reactions: Thibsie
alcoholbob
6,390
470
Hallock even said the 6-30% performance drop is a result of the Balanced performance profile. If you used High Performance at day 1 of launch like many reviewers used, you already have received the benefit of this 6-30% performance boost.
There is some performance boost for a narrow group of APO titles in the 2-14% range coming with Windows 11 2611. There's also a 2-14% performance improvement in some situations already deployed from available 0x114 BIOS.
In other words, the only thing Intel is promising is single digit performance enhancements in January. It's still 7% slower than the 14900K in gaming now, if all we are expecting is vague single digit improvements in January, this update is not going to reach the parity with the 14900K they claimed at launch.
Also most benchmarks are with very slow RAM speeds, the gap between the 285K and 14900K is *huge* when both are paired with fast RAM in this review posted last week by DannyZReviews. We already knew tuned 14900Ks with fast RAM are faster than tuned 7800X3Ds, so it should not come as a huge surprise that the gap between the 14900K and 285K in an enthusiast system is basically insurmountable.
