Page 660 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,482
4,896
I was just about to post that, lol. I'm surprised to see Skymont score higher than raptor lake ISO-clock. That's actually insane.
Saved you the effort 🙂
Imagine Clearwater forest with 5-7% more powerful core than Skymont core that is not held by fabric and 288 of them on 18A
GTracing
478
1,114
Yeah, Intel might actually beat AMD in server performance again.
I also found this interesting. We've seen other reviewers report on the high memory latency for the p-cores, but I haven't seen memory latency numbers for the e-cores. 194 ns is so high that I wonder if they're doing something wrong with the testing. If it's accurate then it makes the e-cores that much more impressive.
Markfw
May 16, 2002
27,406
16,255
Actually, I doubt it. Turin is faster than Intel best desktop, but Turin is another 20-30% faster than its predecessor, due to clock speed PLUS other things.
Reactions: OneEng2
MS_AT
942
1,868
That is expected, the advantage that Raptor had, wider registers, was taken away, with those compiler settings. For int it is less relevant as x264 will be the only subtest to benefit, but from FP point of view it's a different story.
511
5,482
4,896
Turin is a Server CPU based on zen 5/5C.It is faster by 20% in phoronix bench for a single CPU vs GNR .
Desktop and Server share the die Geeker wan gave us number for per core performance.Zen 5 is 7% faster than Skymony in SpecInt and Darkmont is 5-7% faster than Skymont with the slow L3 so you can do the math 192C/384T vs 288C/288T both cores having similar SpecInt 1T performance
Also HT increases AMD MT Performance by 30%
MS_AT
942
1,868
Which SpecInt? Compiled with gcc or clang, icx or aocc? With or without AVX512? With fancy optimization options enabled or disabled? As a curiosity, from M1 review by Andrei
Since our A14 results, we’ve been able to track down Apple’s compiler setting which increases the 456.hmmer by such a dramatic amount – Apple defaults the “-mllvm -enable-loop-distribute=true” in their newest compiler toolchain whilst it needs to be enabled on third-party LLVM compilers. A 5950X with the flag enabled increases its score to 91.64, but also while seeing some regressions in other tests. We haven’t had time to re-test further platforms.
The baseline otherwise for this subtest was 48.00 for 5950x;)
Markfw
May 16, 2002
27,406
16,255
Where is the benchmark you are referring to ? looking at one small number (specint 1T) does not make a faster cpu overall.
511
5,482
4,896
For this one i am assuming same settings as done by Geekerwan Clang -g -Ofast no fancy optimization.Hope this answers your question 🙂
511
5,482
4,896
SpecInt Rate is not a single Number tbh it is an aggregate of multiple test as Industry standard as possible it has many substests.
I agree one small number won't make a CPU faster otherwise people won't be buying Sierra Forest it will in the end depends on the workload
gdansk
4,792
8,084
You're ignoring clock rates
Considerable disappointment follows those extrapolating from only IPC.
511
5,482
4,896
I am not lol i took this graph under consideration but i missed the mesh and imc power and other stuff i have too many variables to account for
gdansk
4,792
8,084
1. Turin-D is on a process with a considerably different v/f curve. The N4P version is still intersecting with N3B Skymont at 2W
2. Turin-D has more than 2W per core vs less than 1.7W per core for Spammontforest.
OneEng2
1,011
1,212
Hopefully we wont have to "Imagine" it :).
I doubt Clearwater is going to retake the throne in DC from Zen 5 in real world application performance, not to mention Zen 6.
Turnin Zen 5 gets 40% MT improvement with SMT per core (which is flat out crazy IMO). Zen 5 also has AVX512. I don't think you can scale SpecInt into general DC workload performance for Skymont. Also, if Intel isn't shipping Clearwater by Q3 2025, they will soon be facing Zen6 with double the number of cores per CCD on 2nm GAA. So a theoretical AMD Zen 6 384C/768T part ;) is what Skymont would be facing for the majority of its existence.
Jan 12, 2021
47
93
Chips and cheese when testing the MTL, he noticed that IMC was sometimes in low power mode when using the E-cores, increasing latency
511
5,482
4,896
1. I forgot that but 18A is superior to N3E which Turin D is using by ateast 5%(TSMC Claims on par with N3P) and Intel claims it is on par with N2
2. No arguments here as i said many variables to account for we have imc and IO power in TDP as well
OneEng2
1,011
1,212
I am guessing that the truth lies somewhere in between. N2>18A>N3P
Reactions: Tlh97 and 511
511
5,482
4,896
I thought it was 30% from the benches done by David Huang.I wasn't talking about AVX-512 Performance cause Skymont will loose there Also 2nm GAA is not shipping before Q4 2026 . Intel has 1 year and than after 9 months if Zen6 we have Arctic wolf with 512C/T rouge river forest 🙂 in 2027
5,482
4,896
Yes definitely i agree IEDM is this December both Intel and TSMC will present their respective 2nm class process 18A and N2 we can find an analysis on Semiwiki by than
Reactions: OneEng2
Hitman928
6,754
12,500
Were those comments for the original 18a specs or the downgraded ones?
Hitman928
6,754
12,500
I thought it was 30% from the benches done by David Huang.I wasn't talking about AVX-512 Performance cause Skymont will loose there Also 2nm GAA is not shipping before Q4 2026 . Intel has 1 year and than after 1 year we have Arctic wolf with 512C/T rouge river forest 🙂 in 2027
N2 with GAA goes HVM in H2 2025.
I don't know but TSMC knows better so I will take their word for it
The timing of the comment matters though, if it was before 18a was downgraded, then the comment may no longer apply.
Reactions: KompuKare
