Page 602 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
19,219
Does Lion Cove even have such "disabled AVX-512 and HT circuitry"?
I hope so! Otherwise they are screwed!
At least when the sales get really bad, they can release some microcode update to unblock both.
It's kinda funny if you think about it. Maybe Intel's first CPU with close to P4 level madness and Conroe level elegance on the same package! :D
Reactions: sgs_x86 and OneEng2
Hulk
4,128
The question then becomes what features are you looking for in an upgrade from a 1 year old top-end CPU (that doesn’t exhibit any instability)?
As I wrote it's honestly more of a just want the newest thing to fool around with.
Most of that gear is built into the Soundcraft UI24r stagebox.
511
5,523
4,910
Not much. Maybe @Hitman928 / @DavidC1 can share some interesting stuff.
Ha ha.. true. All the hype surrounding this gen cpus (both camps) should get back to normal once the reviewers get their hands on them. Making purchase decisions based on hype will make us end up with expensive duds.
MTL had a lot of hype. Many dodged the bullet safely after seeing the reviews. Just feel sad for those who took one for the team.
I took the bullet but i am happy cause i upgraded from 8250u 🙂 it depends from which platform did you upgrade from
Reactions: SiliconFly
Magio
207
246
Comparing against unplugged figures on an undisclosed lower power mode is absolutely ridiculous from Qualcomm. We have the power consumption figures so even if there are power modes in which LNL performance drops that much we still know that it absolutely holds its own against X Elite in ST PPW and that while it's weaker in MT it is capable of giving out its full performance on an unplugged power budget.
It's especially puzzling why they'd go to the trouble of such a biased comparison when showcasing their phone chip (on N3E) which actually does make LNL look quite underwhelming without such cheap tricks from QC.
Philste
308
486
How did they manage to score 1370 on the XPS 9350 /w U7 256V?
Looking at other slides from the presentation, I think it has to do with performance while unplugged. The XPS laptop may be too aggressive with throttling while on battery.
Sadly Windows Power Plans are really bugged with Lunar Lake. My Zenbook S14 behaves the same way. Windows Power Plan Balanced will show these low results, CPU won't Boost and run at ~7W ST and ~13W MT through whole Geekbench 6. It's the same when plugged in.
But battery and plugged in is different power plans, so Qualcomm probably set it to performance and then unplugged it. You have to set it to performance seperately on battery.
And yes, it's overwriting ASUS Power modes, Asus full Power Mode with Windows Power Plan balance on charger still Delivers 1300-1400 ST score.
5,523
4,910
If Windows Disabled Turbo Boost than it is a Problem cause the base TDPs/Frequency are ridiculous my MTL can do. 6*2.3ghz + 8*1.8ghz at 29W in r24 while Intel Ark lists it at 45W for the same clocks
OneEng2
1,013
1,212
I do a lot of multitrack audio work. Playing a gig tomorrow actually that I will be recording and I run sound as well. Soundcraft UI24R stagebox mixer, controlled via wireless, 24 tracks, fx, etc... running the sytem in real time with no perceptible latency to the musicians, 8 aux mixes, feedback control...AND the ability to multitrack record all 24 tracks. It's nuts. 30 years ago it would have taken a good sized box truck full of racks of gear to do that.
I am going to take a good, hard look at the 9950X vs Arrow Lake if I upgrade this generation. I know, I know, there isn't much additional performance to be had from my 14900K. But the sad reality is there are more upgrades behind me than ahead of me if I upgrade at my old rate. This is a fun hobby for me and I splurge more on it these days.
What is the stock all-core clock for the 9950X BTW?
I have both the Ui24 and X32 Rack (I play in a band). I have a friend that has the CQ20B and one with an XR18. My point exactly. These little boxes are doing the processing of an entire 22 space rack full of gear from the early 90's and doing it in real time. All of this is possible through the use of hardware processing dedicated to digital sound algorithms.
My belief is that specific computing hardware can be many orders of magnitude (3 to 4 orders of magnitude) than general computing can be.
I believe that this will drive heterogeneous CPU design moving forward; however, Operating Systems will need to evolve to handle the much more complex scheduling needed.
It may have been present but is disabled considering the die size for ARL-S
Seems like a VERY expensive way to go. Why pay premium prices for N3B die space for a feature you have no intention of enabling? Additionally, Intel previously had thermal issues with running AVX512 due to the many more active transistors.
moinmoin
5,248
8,463
We already have accelerators. GPUs are ones, sound cards pretty much were ones. Specifically lower latency sound mixing I honestly think that ship sailed ages ago already. We had excellent hardware mixing of sound already, but then Microsoft came and instead of standardizing hardware mixing made all the driver models incompatible with the new Windows OS release. Since then cheap on board sound and software mixing had been considered good enough for like 99.99% of all use cases.
Reactions: Thibsie and OneEng2
Hulk
4,128
Or maybe software developers will be able to specifically access certain cores in the CPU through the software for specific routines in the code.
This takes me back to the early '90's when I was using the CardD and Software Audio Workshop (SAW), written by Bob Lentini in Assembly. It was absolutely miraculous that you could multitrack record and mix with a pentium class computer. I was at Javits centers in NY way back when saw the demo of CardD and SAW. I bought them within a week, convining the band we HAD to have them. We also had a small recording studio. I used it instead of a DAT recorder to digitize final mixdown and for mastering. It was fabulous for the time and even holds up today. SAW, coded in Assembly was a few MB and ran from the exe file. It was stable, tiny, fast, and brilliant. I remember Bob had studied the Windows API for a bit and decided he couldn't do this through Windows, it was going to have to happen in Assembly and just made it happen.
Good software can be the way "around" insufficient hardware and it is the more elegant approach. We've already seen what good game drivers can do.
AMDK11
496
441
What's taking up all that die space then? Ideas?
Including larger Front-End, 8x wider predictor, 8-Wide decode, L1-I 64KB, UOP Cache(L0) 5250, Queue 192, ROB 576, Branch Order Buffer 180, Scheduler FP 114 and PRF ~400, Scheduler INT 97 and PRF 290, Execution units on 10 (4x FP + 6x ALU) ports instead of 5 (3x FP/ALU + 2x ALU), Non-Scheduling-Queue Buffer, L0-D 48KB, L1-D 192KB and L2 3MB. + all resource control logic.
Also, splitting the unified FP/ALU scheduler with 97 entries for 5 execution ports into a separate scheduler for 6 ALU units with 97 entries and 4 FP units with 114 entries required large resources.
