Page 601 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
GTracing
478
1,114
C&C doesn't have everything correct, and they also miss things(such as existence of the OD-ILD. Heck they don't even mention it!). Since they had macro op execution in Silvermont, it would have been quite a change to go back to micro op execution in successors. Agner Fog's x86 optimization manual implies even Tremont keeps the same scheme.
Chips and Cheese got that piece of info from an Intel marketing slide. I would be quite surprised if it was false.
Hulk
4,126
Currently Raptor Lake even at an IPC disadvantage can get more done on the P-Cores due to HT. Hence we need more P-Cores not less.
The Best setup was 8P+8E the next best one would be 10P+8E or 10P+16E.
If what you mean by "get more done" is quickly degrading the P cores, then yes, you are correct.
Just kidding of course.
But we'll have to agree to disagree. I side with the Intel engineers on this one.
Reactions: OneEng2
AcrosTinus
221
226
I like the snark, I trust Intel too but a reduction in P-Cores will never happen.
The P-Cores have lost throughput due to the lack of HT and need a higher IPC increase (size of HT benefit) to compensate for that. I hope they go the higher P-Core count road rather than the higher E-Core route, we will see...
Reactions: Hulk
DavidC1
2,187
3,340
I would like further clarification if that's the case, because Intel gets many things in their own slide wrong.
Meteorlake being up to 192EU, when Exist50 said that it never even existed, and it was simply a mistake.
What about the time the server head of Intel paraded a Sapphire Rapids wafer as a Sierra Forest one? Remember that one? We were wrapping our heads on how many cores that "SRF" die had?
Lack of HT is better countered by having another E core cluster, since each E cores are much more powerful than HT anyways, and from a program point of view, it'll take less threads to accomplish the same task, thus more benefit.
Or, the better solution of a peak performing core derived off Skymont or Arctic Wolf.
Hulk
4,126
Who knows? On one hand I understand the hybrid approach. On the other AMD seems to be doing more than okay with the more traditional approach.
OneEng2
1,013
1,212
C'mon, if Intel wins in a bench, the bench sucks cos it is doctored or optimized for Intel. But if Intel loses, Intel sucks! No two ways about it.
Fair comment. I would say that Cinebench comparisons that I have seen don't paint Intel processors in a very good light compared to Zen5:
If it is true that Arrow Lake has equal MT to 14900K, then it would seem to me that Arrow Lake is going to get beaten in MT by Zen 5. I must be missing something in this discussion.
MSVC is objectively the worst compiler of the big three C++ compilers (GCC, MSVC, CLANG) when it comes to generating performant code... The reason people use it when Clang is available directly from Visual Studio with two button clicks is still a puzzle to me;)
To be fair the full quote from C&C is this:
In other words in SPECint aarch64 has the advantage, in SPECfp, x64 has the advantage. Overall, ARM has the advantage. Still I would approach these results with caution as I doubt Chester looked at generated assembly to also check the quality of generated code. I would expect the 16 architectural GP registers are hurting x64 compared to aarch64 in SPECint where it will have to spill more often compared to ARM. In SpecFP, since this is usually more math oriented code, wider SIMD registers could explain x64 advantage. But once again, I am just guessing, I don't have access to SPEC sources so I cannot compile it myself to check;)
I completely agree. Clang (being more open source and community optimized) tends to generate very performant binaries. I would say that for some number of years, Intel has relied on a constant flood of new instructions (which AMD would then be a generation behind on) and specific benchmark optimizations to take advantage of these new instructions, in order to make their processors look better than they would be in general usage. This seems to have slowed
I tend to believe that a heterogeneous approach will prevail in the long run as specific processing for specific workloads can be handled much more quickly with hardware designed to do that work.
In the short run, operating systems are not able to easily handle this new complexity so a more homogeneous chip architecture is likely to do better.
My example is how fast a digital mixer can perform digital signal processing. 48 channels of sound being modified, fed into busses that are modified, summed to a pair of outputs and sent to speakers all in near real-time (< 1mSec). All of this is done with DSP chips designed to handle sound.
AcrosTinus
221
226
I still cannot understand how AMD got to this performance level, Zen is a mystery to me, held back on consumer by memory bandwidth, latency and their chipset (also chiplet to IO-Die bandwidth, on Server they now have 2 links per chiplet). If they solve these points, I might be gone...
Hulk
4,126
I do a lot of multitrack audio work. Playing a gig tomorrow actually that I will be recording and I run sound as well. Soundcraft UI24R stagebox mixer, controlled via wireless, 24 tracks, fx, etc... running the sytem in real time with no perceptible latency to the musicians, 8 aux mixes, feedback control...AND the ability to multitrack record all 24 tracks. It's nuts. 30 years ago it would have taken a good sized box truck full of racks of gear to do that.
I am going to take a good, hard look at the 9950X vs Arrow Lake if I upgrade this generation. I know, I know, there isn't much additional performance to be had from my 14900K. But the sad reality is there are more upgrades behind me than ahead of me if I upgrade at my old rate. This is a fun hobby for me and I splurge more on it these days.
What is the stock all-core clock for the 9950X BTW?
jdubs03
1,503
1,092
The question then becomes what features are you looking for in an upgrade from a 1 year old top-end CPU (that doesn’t exhibit any instability)?
Maybe the answer to that will be clearer in 3 days 😄
You’d have to deal with the switching costs too, and probably a depressed resale market for that 14900K.
Oh and that’s a lot of sound equipment. Is that typical of a band that does local/regional gigs?
Markfw
May 16, 2002
27,406
16,256
I am not sure what the spec is is anybody's else's result. I am getting 4.6 @ 100% load
coercitiv
7,495
17,913
Looking at other slides from the presentation, I think it has to do with performance while unplugged. The XPS laptop may be too aggressive with throttling while on battery.
I don't have time to go through all the slides and notes, but at least this would make sense in terms of measurements. (how that Dell is configured from the factory is another issue altogether)
